Thread: Oil pressure warning stop! immediately 1.9tdi
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    Quote Originally Posted by Rob69 View Post
    Check your batttery voltage is ok should be around 12.5 V or slightly more with engine off, it sounds more like electrical gremlins than mechanical problems, start the engine briefly and check voltage while running, should be 14.5V. If voltage is ok you'll need a vcds scan to start diagnosing the problem.
    Just gone to back to the car and the battery is dead....
    Sent from my Pixel 2 XL using Tapatalk
  2. Re: Oil pressure warning stop! immediately 1.9tdi
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That is true and crossed my mind that the big end(s) were wiped but wouldn't explain the electrical glitches, anyway looks like he's needing to find a battery first.
    Quote Originally Posted by Gazwould View Post
    BXE isn't the best engine code as the upper conrod bearings like to wear through and spot weld to the crank...
  3. Re: Oil pressure warning stop! immediately 1.9tdi
    Mar 2018
    Loughborough
    I've taken the car to a garage now and the immobiliser keeps kicking in now !
  1. STOP oil pressure warning - oil pump failure! Help please
    By jamer78 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 03:54 PM
  2. Please Help Stop engine/oil pressure warning light comes on
    By GnasheRRR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-10-2011, 11:05 AM
  3. STOP! engine oil pressure warning
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-11-2008, 03:19 PM
  4. Engine Oil Pressure Warning (STOP) - please help
    By Nedx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-10-2008, 10:41 PM
  5. STOP ! Low Oil Pressure Warning
    By Tnarg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2008, 11:33 AM
