Thread: Hardwide Dashcam
Results 1 to 9 of 9
  1. Hardwide Dashcam
    Feb 2018
    Fife
    8 Post(s)
    On previous cars, I have hard wired the dashcam to the fuse board - On the Yeti, it was a simple task to take off the A-Pillar trim and run the feed invisibly to the fuse board.
    I have looked today to do the same on the A6 and struggling - have seen a lot of the other threads on here but thought I had seen one that hardwired to a 12v supply in the interior light - anyone seen that and find it again?
    If I do go the A-Pillar route, any tips for removing the screw from the trim without it dropping and rattling for the next three years?
    TIA,
    Steve
  2. Re: Hardwide Dashcam
    Aug 2009
    Near Lanark
    21 Post(s)
    Buy something like this....
    12v Female Car Cigar Cigarette Lighter Socket Plug Connector High Quality 2M 5A | eBay
    Just remember to put a 5A fuse on the positive side.
    Simply plug your dash cam into it once you've connected it to a power supply.
    Mine is connected to a switched supply which happened to be blank. Positive side is a blade fuse chopped away to leave simply the blade and that's securely connected to the above linked socket. The negative side I put a ring connector on the end then split it open to use the bolt holding the dashboard in place - it's a big bolt and the ring wasn't big enough without splitting it.
    As for running the cable, mine is tucked into the headling and into the A pillar without removing it. There is one short section of visible cable at the bottom of the A pillar because I couldn't open up a gap between the dash and the trim. But it's very subtle and the cable is hardly noticeable.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  3. Re: Hardwide Dashcam
    Feb 2018
    Fife
    8 Post(s)
    Quote Originally Posted by darich View Post
    Thanks, already have the 12v socket and piggy back fuse (the cam was in my previous car) - its more the routing and possible use of the dome light wiring I was looking for.
  4. Re: Hardwide Dashcam
    Mar 2014
    Edinburgh
    235 Post(s)
    The thing to be careful if you are routing cable around the a pillar is the airbag. Anything in the way of it deploying could have catastrophic consequences and it’s also pretty expensive if you break the airbag.
  5. Re: Hardwide Dashcam
    Feb 2018
    Fife
    8 Post(s)
    Quote Originally Posted by A6S View Post
    Hence why hoping to go to the dome light :-)
  6. Re: Hardwide Dashcam
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by Tomo1971 View Post
    Depending on the charger you might blow a fuse with the dome light.
  7. Re: Hardwide Dashcam
    Jul 2017
    Maidstone, Kent
    49 Post(s)
    You can route the power cable under the air bag, have a look at this thread. I tried to do it initially and abandoned the idea, but re-visted last week and have now run the cable under the airbag, it is easy to do, but needs some effort pulling the A-pillar lining away whilst running the cable under the airbag.
    Dash cam wiring - Page 2
    Audi A6 Avant 2019 Black Edition, C8, 3.0TFSI S Tronic. Tech Pack, Parking Pack, Tow Bar, Tour pack.
  8. Re: Hardwide Dashcam
    Apr 2016
    London/UK
    23 Post(s)
  9. Re: Hardwide Dashcam
    Feb 2018
    Fife
    8 Post(s)
    Turns out much easier than anticipated.
    My biggest fear was the screw (T25) holding the A-Pillar trim in, I didnt realise at first it was captive in the plastic trim, in so much as it wont drop down the A-Pillar, although if anyone reads this, as soon as its loose, take it out - I had to pull the trim out a little and the fastener 'popped' and the screw jumped and did drop drop down the inside of the trim. Luckily I retrieved it.
    Was easier enough to get the cable behind the airbag, just pulled the trim as far as I dared at the top and pushed it through, routed under the lip of the headlining and into the area above the dome lights, just to basically secure it there behind a cable and to leave a little slack if ever I change cam or mount.
  1. Dashcam placement
    By vince47 in forum Passat - B8 Forum - 2015 -
    Last Post: 09-02-2018, 11:37 AM
  2. Dashcam opinions?
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-01-2018, 11:41 AM
  3. Q7 dashcam?
    By Gyro in forum Q7 - 4M Forum - 2016 -
    Last Post: 24-04-2016, 07:46 AM
  4. dashcam
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 10-12-2015, 05:08 PM
  5. Dashcam on A6
    By Warthog21 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-07-2015, 10:22 PM
