Thread: P0183 Fuel Temeperature Sensor fault code
  1. P0183 Fuel Temeperature Sensor fault code
    Mar 2018
    Bracknell
    New member to the forum and hoping someone can help solve an issue with an Engine Management issue.
    I have a 2005 diesel golf which recently showed Engine Management light using a code reader it highlighted P0183 - Generic Current Fuel Temperature Sensor A circuit high. I have changed the sensor and reset and car can be run without warning showing, however once ignition is turned off and on again warning code returns. I have checked resistance against temperatures of old sensor and it appaers to be ok.
    Has anyone had similiar problems or can give me an idea what to check next.
    Many thanks
    Graham
  2. Re: P0183 Fuel Temeperature Sensor fault code
    1837 Post(s)
    I think you are in the wrong forum section, can you confirm this is a Golf 4 model (type 1J) and what is your engine type code such as BXE?
  3. Re: P0183 Fuel Temeperature Sensor fault code
    Mar 2018
    Bracknell
    Thanks for the heads up I have posted in wrong forum as its a MK5. I have posted the question hopefully in the right forum now. Thanks for your help.
  1. Please Help Touran 2006 1.9TDi Fault Code 18000 / P1592 MAP Sensor fault?
    By frozenman77 in forum Touran - Sharan - Caravelle
    Last Post: 12-01-2016, 12:31 PM
  2. help with fault code 16575 fuel pressure sensor
    By justin@justinwa in forum Golf MK5 - 2004 - 2009
    Last Post: 28-04-2012, 05:40 PM
  3. 3.0Tdi - P0183 fault code
    By seventh-heaven in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-09-2011, 11:12 PM
  4. fault code 1121 fuel pressure sensor
    By IRISH QUATTRO in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-01-2011, 07:43 AM
  5. Replies: 0
    Last Post: 24-01-2010, 12:57 PM
