Thread: Audi A6 highline clocks redline coding
Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 111
  1. Re: Audi A6 highline clocks redline coding
    #51
    Mar 2013
    Reading
    31 Post(s)
    Quote Originally Posted by sarah1331 View Post
    So even as factory fitted rmc and highline clocks map in dis won’t work?
    Sent from my iPhone using Tapatalk Pro
    I've got a colour DIS and RMC from factory (on 13 reg Avant, CDUD engine).
    My red line changes as described by few other posters and my DIS shows satnav directions rather thank the full map. Can post pics if you want.
    I don't have VCDS but OBDeleven and provide the module scans if needed (just let me know which ones as grabbing them all is not as simple as it is with VCDS /at least to my knowledge/).
    Sent from my mobile...
  2. Re: Audi A6 highline clocks redline coding
    #52
    Mar 2014
    Edinburgh
    235 Post(s)
    As far as I know this requires the mmi plus/4g. The dis will only show compass, directions and street name but not full map.
    For U.K. spec cars you can only get the colour dis as part of the tech pack which included the mmi plus.
  3. Re: Audi A6 highline clocks redline coding
    #53
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by Johnny31 View Post
    The maps on dis wasn’t available on the prefacelift. This was a facelift addition and requires the new mmi with the nvidia tegra chips to work. Also the reason why things like vim coding don’t work as the architecture is completely different.
  4. Re: Audi A6 highline clocks redline coding
    #54
    Jan 2018
    Mexborough
    26 Post(s)
    I have a facelift 2016 factory rmc and highline clocks retrofitted
    Why did they put fibre optic cable from rmc to highline clocks these serve no pourpose unless you can have maps
  5. Re: Audi A6 highline clocks redline coding
    #55
    Mar 2014
    Edinburgh
    235 Post(s)
    Could it be sending information like speed, street names, direction across the fibre cable?
  6. Re: Audi A6 highline clocks redline coding
    #56
    Jan 2018
    Mexborough
    26 Post(s)
    Need someone with rmc to confirm as mine doesn’t show names just the arrows I don’t have FOC connected
  7. Re: Audi A6 highline clocks redline coding
    #57
    Mar 2014
    Edinburgh
    235 Post(s)
    My pre facelift with black and white dis showed street names and other info from the sat nav so it’s probably coming from the foc
  8. Re: Audi A6 highline clocks redline coding
    #58
    Jan 2018
    Mexborough
    26 Post(s)
    My monochrome showed street names but the don’t have FOC am at caravan so struggling to do some tests roll on tomorrow evening
  9. Audi A6 highline clocks redline coding
    #59
    Jan 2018
    Mexborough
    26 Post(s)
    Can you scan convenience module and post?
  10. Re: Audi A6 highline clocks redline coding
    #60
    Mar 2014
    Edinburgh
    235 Post(s)
    Is there an engineering menu in the rmc unit? Or maybe some coding somewhere(5f)?
    Maybe something needs turned on In there for information to flow through fibre optic.
  1. Audi s3 2015 clocks coding. Kph to mph
    By Jms1390 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 21-06-2015, 08:46 PM
  2. Please Help **** RNS 510 & Highline MFD coding ****
    By 2Dcadman in forum In Car Entertainment
    Last Post: 29-12-2012, 08:42 PM
  3. North West, Clocks Coding?
    By Waz88 in forum VCDS - Help Requests
    Last Post: 03-01-2012, 08:52 PM
  4. Question Highline Midline clocks for B6
    By Norfolk-Boy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-10-2011, 05:52 PM
  5. MFSW And Highline Clocks
    By mjom89 in forum Golf MK5 - 2004 - 2009
    Last Post: 25-02-2009, 12:46 PM
