Thread: help! 34-level control fault wont adapt
  1. Exclamation help! 34-level control fault wont adapt
    west yorkshire
    Hi Q7 is playing up bad, here are my fault code.
    2 Faults Found
    02250 - Function Deactivation; Valve Duty Cycle
    001 - Upper Limit Exceeded
    Freeze Frame
    Fault Status: 11100001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 186151 km
    Time Indication: 0
    Date: 2018.03.22
    Time: 12:37:09
    Freeze Frame
    Error Code: 46
    01437 - Control Position not Learned
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 186151 km
    Time Indication: 0
    Date: 2018.03.22
    Time: 12:37:10
    Freeze Frame
    Error Code: 6
    i have replaced both rear control valves and the suspension relay and all fuses are ok. It wont allow me to enter adaption with car running, when i go ignition only i can log in using 31564, then if i start the car it will allow me to log in. when i go adaption, it just hangs on wheel 1 with 'waiting' then locks out. when i log in agan and if i go to channel 1,2,3,4 for the wheels in adaption settings, adjust test, save, channel 5 is not avilable. if anyone can help, or is near Huddersfield please let me know.
  2. Re: help! 34-level control fault wont adapt
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Are you dealing with the J197 Suspension control unit with VCDS? Try Adaptations.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: help! 34-level control fault wont adapt
    west yorkshire
    Hi, it wont let me adapt at all. changed rear driver side sensor, all measure blocks show green and movement. channel 5 wont 'unlock' to save '1'.
  4. Re: help! 34-level control fault wont adapt
    Aug 2016
    Szeged, Hungary
    Sorry for the old thread bump.
    Delete all the related DTCs, than make adaptation with the factory values instead of the measured! If it lets You change the value from 0 to 1 at block 5, than save it. Stop the engine, take out the key. And after You could start the normal adaptation procedure.
  5. Re: help! 34-level control fault wont adapt
    west yorkshire
    hi, i fixed this, i changed the brain in the boot, it adapted straight away no issues. i still have 2 valves used no fault, 1 brain (not sure will adapt as i think it was so confused) and 1 genuine pump (was no sssues working fine) as changed pump to be on safe side.
  6. Re: help! 34-level control fault wont adapt
    Aug 2016
    Szeged, Hungary
    Than sorry for reopen old wounds
    Once I have started an adaptation process and the middle of it the poor laptop has just died. From that point I have had the very same symptoms You mentioned - it was simple denied all attempt to make level correction. At the peak of my desperation I was feeding it with the factory values and voila , just happened to come back alive.
  1. SQ7 - ABT Remap/Sound Control/Level Control
    By A7_UFO in forum Q7 - 4M Forum - 2016 -
    Last Post: 06-02-2018, 08:50 PM
  2. Question Yellow oil level light wont go off
    By ARW-360 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-12-2011, 04:27 PM
  3. A6 Avant 2 Wheel Level Control (Help Please)
    By snugglebum in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2011, 09:42 PM
  4. oil level warning lamp wont go out
    By justin@justinwa in forum Golf MK5 - 2004 - 2009
    Last Post: 20-04-2011, 09:04 PM
  5. Allroad level control electrical fault
    Last Post: 29-08-2009, 07:13 AM
