Help please.
Have an issue with my sons A3 2.0TDI lots of errors etc PLEASE SEE SEPARATE THREAD FOR DETAILS
Found a local chap who helped out with a VCDS scan last night
came up with lots of errors , some of which he could clear, but came back later
The printout is below.
Can anyone point me at the common culprit please?
Wednesday,21,March,2018,18:39:25:22001
VCDS Version: 18.2.0.3 (x64) HEX-NET CB: 0.4411.4
Data version: 20180212 DS287.0
Ross-Tech: Home
VIN: WAUZZZ8P28A202456 License Plate:
Mileage: 144770km-89955mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 76
VIN: WAUZZZ8P28A202456 Mileage: 144770km-89955miles
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Sporadic communication error 1000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC G000SG 9828
Revision: --H08--- Serial number: AUX7Z0H3FNS039
Coding: 0000072
Shop #: WSC 06314 000 00000
VCID: 6FAE3FD97EC8FD3CF1-803A
7 Faults Found:
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 254
Reset counter: 255
Mileage: 144687 km
Time Indication: 0
Date: 2018.03.18
Time: 04:31:18
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 0.0
005687 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 180
Reset counter: 255
Mileage: 144687 km
Time Indication: 0
Date: 2018.03.18
Time: 04:31:25
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11101000
Torque: 158.6 Nm
Bin. Bits: 00000100
Freeze Frame:
Fault Priority: 3
Reset counter: 255
Mileage: 144687 km
Time Indication: 0
Date: 2018.03.18
Time: 04:31:18
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101000
Bin. Bits: 00000000
(no units): 0.0
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Reset counter: 255
Mileage: 144687 km
Time Indication: 0
Date: 2018.03.18
Time: 04:31:49
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.40 V
Bin. Bits: 00001100
Bin. Bits: 11000000
(no units): 0.0
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 255
Mileage: 144688 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:41
Freeze Frame:
RPM: 1428 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.48 V
Bin. Bits: 11001100
Bin. Bits: 11000000
Bin. Bits: 00100001
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Status: 01110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 144772 km
Time Indication: 0
Date: 2018.03.18
Time: 03:22:19
Freeze Frame:
RPM: 2562 /min
Speed: 133.0 km/h
Load: 100.0 %
Voltage: 14.29 V
Bin. Bits: 11001000
Absolute Pres.: 2325.6 mbar
Absolute Pres.: 2590.8 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
VCID: 73A633A912E0D9DC15-8026
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4220
Revision: 91H01422 Serial number: 003CP003UCCB
Coding: 0071612
VCID: 4BD68B492A90E11CBD-801E
Subsystem 1 - Serial number: 6332DRB4072ACD11T
Subsystem 2 - Serial number: 6342DRB4072ACCB4%
Subsystem 3 - Serial number: 63528RB403BB21BAT
Subsystem 4 - Serial number: 63628RB403BA3572M
Subsystem 5 - Serial number: 63747RB403C87922Q
Subsystem 6 - Serial number: 63847RB403C878FF9
No fault code found.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 951 K HW: 8P0 920 951 K
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 1243H003102388
Coding: 0004423
Shop #: WSC 00006 067 57207
VCID: 3D32D59164245FAC33-8068
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 194
Time Indication: 0
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K085310DB3
Coding: E9807F0E1002022103
VCID: 3522CDB15C1487ECFB-8060
13 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 194
Mileage: 144541 km
Time Indication: 0
Date: 2018.03.06
Time: 17:40:45
00470 - Company Comfort Databus in Single Wire
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 16
Reset counter: 194
Mileage: 144667 km
Time Indication: 0
Date: 2018.03.16
Time: 21:21:31
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Reset counter: 154
Mileage: 144680 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 37
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:02
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:02
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:04
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:04
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 51
Reset counter: 154
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:04
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 51
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:04
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:05
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:00:05
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 194
Mileage: 144680 km
Time Indication: 0
Date: 2018.03.18
Time: 00:02:03
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H22003 Serial number: AUX7Z0H3FNS039
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels:
VCID: 55E26D31AC54A7EC1B-FFFE
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3620CABD41128CF4F2-8062
2 Faults Found:
00750 - Warning Lamp
Freeze Frame:
Mileage: 144650 km
Temperature: 5.0°C
Voltage: 12.50 V
Voltage: 12.30 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674802561857
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
End----------(Elapsed Time: 00:47, VBatt start/end: 11.7V/12.0V)-----------
