Thread: Where is the reversing sensor control unit?
Results 1 to 10 of 10
  1. Where is the reversing sensor control unit?
    Aug 2010
    St. Austell, Cornwall
    Hi all,
    I’ve had a constant beep from the reversing system for a week or so now. It seems to be the main unit rather than a sensor, because I have the optical option enabled (little graphic pops up on the Mmi when reversing is selected) and it just about pops up when reverse is selected. Then it immediately vanishes and a constant beep is emitted. If it was just one sensor, then I’d expect the graphic to stay there, and one sensor image would be all over the shop.
    So, my question is, does anyone know where the main unit might be? Or what it may look like? Then I can check connections, and if necessary get a new unit?
    Thanks for any help,
    Eddie.
  2. Re: Where is the reversing sensor control unit?
    Jul 2008
    Lisburn
    15 Post(s)
    That's a duff sensor. It can't work as expected so shuts down and long beep is to let you know...
  3. Re: Where is the reversing sensor control unit?
    ☝�� What he said. Mmi shuts down.
  4. Re: Where is the reversing sensor control unit?
    Jul 2017
    Blackpool, England
    The sensor unit is just behind the boot, right hand covering.
  5. Re: Where is the reversing sensor control unit?
    Jan 2016
    Wiltshire
    Quote Originally Posted by eddie_fb View Post
    Hi all,
    Eddie.
    You can hear when a sensor is duff. Put the ignition on, select reverse gear then walk around the car and put your ear to each sensor. They make a ticking noise. If you don’t hear the ticking then that’s the culprit. Be aware, depending on the age of the car that the sensor may be fine but the wiring has a break in it.
  6. Re: Where is the reversing sensor control unit?
    Jul 2008
    Lisburn
    15 Post(s)
    Click test told me front right center. Scan revealed rear left center.. .
  7. Re: Where is the reversing sensor control unit?
    Jan 2016
    Wiltshire
    Quote Originally Posted by swalker View Post
    Click test is probably most accurate. If you’re inclined you could swap one of the sensors that does click for the one that doesn’t. This will eliminate whether it’s the sensor or the wiring at fault. The rear left centre fault may be an additional fault but you’re probably as well starting with the front right centre. This one failed on our Alhambra and it turned out to be a break in the wiring loom.
  8. Re: Where is the reversing sensor control unit?
    Aug 2010
    Sorry everyone, should have updated this thread, but forgot all about it.
    You were all correct, a click test showed the inner left sensor to be up the duff, so I splashed out on a painted one from eBay Germany for £35.
    Installed very quickly, and now all sorted.
    Thanks all!
  9. Re: Where is the reversing sensor control unit?
    Jan 2016
    Wiltshire
    Thanks all!
    A good result. Glad to be of help.
  10. Re: Where is the reversing sensor control unit?
    Jul 2008
    Lisburn
    15 Post(s)
    yea since i posted my intermittent fail became total fail and a further scan revealed that the front right center is also out...
    Stewart
    1986 coupe quattro (kv)
  1. Transmission control unit or transmission output sensor?
    By yase12 in forum New Member Introductions
    Last Post: 29-08-2014, 08:24 PM
  2. Should I replace the parking sensor control unit myself?
    By noetus in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-02-2013, 06:17 PM
  3. Parking sensor control unit for allroad 2005 ltd edition tdi auto
    By garyizme in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-12-2012, 02:47 PM
  4. Question reversing sensor
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-03-2010, 02:07 PM
  5. Locating Central control unit and window control unit
    By AdamPhillips88 in forum Touran - Sharan - Caravelle
    Last Post: 23-04-2007, 08:59 PM
