Thread: C7 facelift, MMI Nav+ problem with iphone nav apps
  1. C7 facelift, MMI Nav+ problem with iphone nav apps
    Mar 2018
    Essex
    Picked up a new to me 2016 A6 BiTdi C7 today.
    Awesome car, very very happy apart from one problem.
    I use Waze on my iphone and as audi nav is rubbish. And I want the MMI Nav to stay in the close position.
    Problem is, with the mmi nav closed by using the button, every time waze gives me directions, it opens, says its thing “turn left, whatever” then closes again!
    Rather annoying..
    Only way to stop it opening and closing is to leave it open, which i dont want.
    Any ideas?
  2. Re: C7 facelift, MMI Nav+ problem with iphone nav apps
    Jul 2016
    Chestfield kent
    41 Post(s)
    Hi Don't know about using an App, but the Audi system works fine with the screen down (main), giving voice commands when needed. For screen down just press the top button to the right of the main screen. What is it about the Audi system that you do not like, it works well, gives good definition and can be used, if you want, with Google maps. Do you have the Tech pack or the SD card based system ?
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  3. Re: C7 facelift, MMI Nav+ problem with iphone nav apps
    Mar 2018
    Essex
    Hi, I guess i just like getting a better avatar on my waze app
    Its only a problem with apps and iphone, everything as you say with the standard system is ok. But my choice is to use an app and the mmi opening and closing every time it says something sucks.
  4. Re: C7 facelift, MMI Nav+ problem with iphone nav apps
    Jul 2016
    Chestfield kent
    41 Post(s)
    Hi. Thinking about this if I am using the iPod in the car and the passenger uses the iPod controls the main screen pops up with the change then retracts. So could be a setting that triggers this from the MMI so maybe there is something that can be changed using VCDS. Have a look in the VCDS tricks thread there may be some info there.
  1. Question AMI cable to connect iPhone 6 to AMI in A6 2015 facelift model
    By Pbro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-10-2016, 05:22 PM
  2. Audi MMI Apps
    By Nemo78 in forum Q7 - 4M Forum - 2016 -
    Last Post: 04-12-2015, 11:17 PM
  3. Must-have apps
    By Brycie in forum Home Tech Shed - Sponsored by MailDroid
    Last Post: 19-01-2013, 10:38 AM
  4. Audi iOS Apps
    By Guest 2 in forum Chat - Anything with wheels
    Last Post: 08-07-2012, 02:57 PM
  5. Which apps do you have on your phone
    By onemanparty in forum Home Tech Shed - Sponsored by MailDroid
    Last Post: 28-07-2010, 08:37 PM
