Thread: Car cut out. Injectors? Fuel Pump? Please help!
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Car cut out. Injectors? Fuel Pump? Please help!
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by lorda4 View Post
    I haven't had a look at the car yet - it was far too cold yesterday. I want to test the fuel pump first of all. Does anyone think I would have an issue disconnecting the fuel supply hose from the pump in situ and replacing with a bit of hose that I could catch any fuel in a bucket, then crank the engine to see if any fuel is pumped? Would this cause any issues with the fuel system (air etc)?
    Not a great idea for several reasons. Unless you disconnect the injector loom the car will try to fire, and may run for a short amount of time drawing air (as you have suggested) into the fuel lines, emptying the filter and subsequently drawing air into the tandem pump which in turn will shove it into the head and injectors. A lot of air in a fuel system is not a good thing. Testing it in situ with an alternative power source is also a no no as it's fuel and explosive.
    Remove from the tank (keeping everything around the hole very clean - do the cleaning before you start and be very thorough do not drop or let anything fall into the tank) then test it elsewhere with a limited, controlled amount of fuel.
  2. Re: Car cut out. Injectors? Fuel Pump? Please help!
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    You could insert a T piece into the fuel line with a restrictor in the pipe going to your container.
    Enough fuel would then go to the filter/ tandem pump to avoid any air getting in.
    Should then get a small but continuous flow into you container while the tank pump runs.
  3. Re: Car cut out. Injectors? Fuel Pump? Please help!
    Jan 2012
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by philipharmes View Post
    Or do this - good suggestion thanks Phil 👍
  4. Re: Car cut out. Injectors? Fuel Pump? Please help!
    Nov 2010
    Sussex
    I hate threads that don't conclude with the results, so here is a follow up!
    I ended up connecting VCDS and using that to try and run the pump (engine control module>basic settings> 035). When I did this, there was no noise at all from the pump. To check, I did put a hose onto the outlet and then used VCDS to run the pump - no engine cranking so no issue with air. Again nothing, so was pretty sure it was the pump.
    It's taken ages to get the part - ended up cancelling my order, and getting it from ebay. Just fitted it and the car runs so it looks like this was the issue!
    Thanks for the help on this one!
  5. Re: Car cut out. Injectors? Fuel Pump? Please help!
    Jan 2012
    10 Post(s)
    87 Post(s)
    Good result - I am just about to attempt a refurb on my old pump - heat gun and plastic trim removal tools at the ready. Found the right motor for £20. Just a little 'see-if-I-can' type project.
  1. Please Help Fuel injectors
    By ianbro in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-01-2016, 07:30 PM
  2. Oil Leak around Fuel Injectors
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-05-2014, 07:44 AM
  3. Given oil pump, injectors & DPF issues - What year 2.0tdi is the least risky??
    By SB_TDI in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-08-2011, 12:10 AM
  4. Question fuel injectors
    By N.BEE in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2011, 08:19 PM
  5. Question fuel injectors comparing
    By Docho in forum 80 - 90
    Last Post: 04-09-2010, 09:37 PM
