Thread: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
Results 1 to 10 of 10
  1. Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    As per the title really? Is it easy, accessible and can you do it with standard everyday tools?
    All input is very gratefully received.
    The Only Way Is A6!
  2. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    Nov 2016
    england
    33 Post(s)
    Quote Originally Posted by Brycie View Post
    Have you attempted it?
  3. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    No, not without some advice first & nobody posted any advice.
    The Only Way Is A6!
  4. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    May 2014
    Darlington
    78 Post(s)
    Give us a clue on the engine size, if it's the v10 engine then I would say not a chance but if it's the 2.0TDi, then I would say it would be a simple job.
  5. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    Jan 2018
    Newcastle upon Tyne
    I've got a 2.5 diesel one
  6. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    May 2014
    Darlington
    78 Post(s)
    The 2.5 engine will be from a C5
  7. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    Jul 2013
    76 Post(s)
    The poster has a 2.0 tdi it’s in the signature.
    Its should be ok but invest in a set of xzn sockets bit set to be sure only around £10 for a set on eBay.
    Dan
    2009/2010 2.0 TDIe SE
  8. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    May 2014
    Darlington
    78 Post(s)
    I have signatures disabled, they can sometimes be bigger than the posts, makes the treads twice as big as they should be.
  9. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    Mar 2011
    Clitheroe, England
    11 Post(s)
    I didn't realise you could disable signatures. Will try to remember to include engine/model details on future posts then.
    Shame, the car has always fired up with barely even a single turnover - until of course, I decide to sell it & then the starter motor starts taking a few seconds of spinning up before starting.
    Thanks for the advice guys. I'll have a look into prices if you reckon it's a DIY job then.
    Cheers.
    The Only Way Is A6!
  10. Re: Is changing the starter motor a DIY job on an A6 C6 Pre-facelift?
    May 2014
    Darlington
    78 Post(s)
    Just remember to disconnect the battery...
  1. Question How do i fit a starter motor?
    By muchos04 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-05-2010, 09:20 PM
  2. Please Help Non starter - suspect starter motor.
    By 94golfcl in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:09 AM
  3. CHANGING A STARTER MOTOR 2001 SDi golf
    By bigbrian123 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2008, 11:29 PM
  4. starter motor
    By ghostrider in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2008, 12:10 AM
  5. Starter Motor
    By Ewster in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2008, 11:06 PM
