Thread: 2012 Passat 2.0 TDI sport will not start or turn over
Results 1 to 10 of 10
  1. 2012 Passat 2.0 TDI sport will not start or turn over
    Mar 2018
    balivanich. Isle of Benbecula
    Looking for some advice/help
    About a week ago my Passat had issues in starting. It would start but with low revs only and the engine management light on, second handbrake light on amber with line through it and warning that ESC was not operating. engine cut out after about 5secs.
    On the third attempt of trying to start it started normally without any errors on display. took it for a test drive and all appeared to be ok.
    Couple of days later went to use car and the display comes on when you insert the key and the above warnings appear on display. when you push the start button to fire up engine display blanks out and nothing happens except after about 5 seconds the radiator fans come on full blast and will not stop until the key is removed.
    on trying to test with code reader the first one could not communicate but an alternative one gave the following information
    ABS:
    01314 - Engine Control Module (ECM)
    Parking brake:
    03200 - Button for Electrical Parking Brake (E538)
    Power steering:
    Instrument cluster:
    12648448
    Immobilizer:
    01176 - Key Faulty
    Central electronics:
    00526 - Brake Light Switch (F)
    00907 - Intervention load Management
    03678 - Co-ordinator Start-Stop Function
    Driver's door:
    68108
    Front passenger's door:
    68108
    Heater & air conditioning:
    13701376
    CAN network gateway:
    Media player:
    Our local mechanic suggested we try battery which we replaced with a new AGM battery but no difference.
    He came to house and has checked all fuses and relays and also checked for the 3 earths and 3 lives at ecu which are present. also checked two inputs for 2.5v plus and minus square wave which are also present.
    he is sure that ECU is at fault
    1 - is there anything else that we have missed
    2 - can the ECU be repaired and can you suggest an agent for this or is it VW only for this repair.
    Geoff
  2. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Get a scan done with VCDS, if you can locate someone with it, those codes look like they are from a generic reader. What voltage do you have at the battery terminals when the car is off and then when engine running? those codes look related to low voltage at first glance and not all of them relating to engine ECU, there are codes from other modules there, plus the fact your dash warning lights cleared once it was running. BBS reman do ECU's if you're sure sure though
  3. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Mar 2018
    Codes given are from generic reader and we originally thought it was battery so the new one was put on but not difference. Cannot give volts when started as it will not start or even turn over but the original battery charged is 12.7v and the replacement battery is now at 12v.
    warning lights are there now when ignition switched on but when you press start button the display goes off as if you have removed key from slot.
    Geoff
  4. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Nov 2010
    104 Post(s)
    Sorry I can't be much more help, other than thinking it is still voltage related, can you try carefully connecting to another vehicle with jump leads, as your original and new battery might be showing good voltage under no load but dipping when ignition is turned on.
  5. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Mar 2018
    Thanks for help. e did try a jump start early on but no joy. battery voltage is static when we try to start at 12v or 12.7 which ever one is fitted. Just going to have to bit the bullet and send off the ecu for testing.
    Thank you again
  6. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Mar 2018
    scunthorpe england
    hi, something similar with my passat - 2013 2.0tdi 174 - was driving perfectly fine then all of a sudden loss of power, followed 10 seconds later by the car dying. since then it wont start, and has a ESC fault. ive tried jumping it, it wont jump, ive charged the battery for 16 hours, with a stable voltage of 12.5v prior to an attempted start. when i put the fob in and attempt a start it sounds as if the car doesn't even attempt to start but the radiator fan comes on.
    any ideas?
  7. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Apr 2020
    Quote Originally Posted by simpz7 View Post
    any ideas?
    Did you ever get to the bottom of this because I have the exact same issue!
  8. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Jan 2016
    Winchester Hants
    29 Post(s)
    Quote Originally Posted by Pandaman5005 View Post
    Not been active for 2 years...
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  9. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Aug 2020
    Croatia
    Hi, did anyone solved this problem please. I have the same problem with my passat b7 2.0tdi. Any help please.
  10. Re: 2012 Passat 2.0 TDI sport will not start or turn over
    Apr 2020
    Hi, yes I did, the ECU failed and was not recoverable. In the end I had to buy an ECU set from eBay and change about 4 bits of kit on the car.
  1. VW Passat 2012 - Won't start - Dash lights on but only silence
    By Mike45 in forum Chat - Anything with wheels
    Last Post: 21-01-2018, 05:31 PM
  2. Passat TDI BMT will not start or turn over - odd things happening!
    By jamesmerrix in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 08-01-2017, 03:56 PM
  3. Question Wet start problem(s).... VW Passat Sport Estate 2007 2.0 TDI (170)
    By nick.king in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-11-2014, 01:49 PM
  4. Please Help 03 Passat tdi sport - Cut Out & now won't start
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-05-2013, 03:42 PM
  5. Please Help passat mark 5 , wont turn over , wen jump start, lights dont work
    By Al_Killya in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2009, 02:38 PM
