Thread: Passanger Door lock - help required
  1. Passanger Door lock - help required
    Feb 2014
    Felixstowe
    Hi all
    I have an A6 allroad C6 2009 with a faulty door lock, won't open from the outside. now I've had a look round the forum and decided to do the work myself and get a lock from evil bay. Well the lock turned up yesterday Pt No 4F2 837 015 (A3 8P) and looks in good condition but looking at the electrical connector it has 8 pins? my question is - before I take the door apart is this correct or should it have 9 pins? Help
  2. Re: Passanger Door lock - help required
    Jul 2013
    76 Post(s)
    The drawing shows only 7 pins used.
    The lock should be a 4F2 837 015 or 4F2 837 015 B or 4F2 837 015 D or 4F2 837 015 E.
    The later ones have more PR codes.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Passanger Door lock - help required
    Feb 2014
    Felixstowe
    Thanks for the info Dan, so am I right in thinking that because my lock does not have a letter after the code just finishing 015 it will not work? Not overly keen on taking the lock out of the door and finding the new lock I have is no good.
  4. Re: Passanger Door lock - help required
    Jul 2013
    76 Post(s)
    I made a typo the 015 one without the letter is correct.
    Dan
  5. Re: Passanger Door lock - help required
    Feb 2014
    Felixstowe
    thanks Dan, at least I know the locks compatible.
  1. Question Passat B5.5 Estate needs tailgate microswitch and rear passanger door lock repair
    By berrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:50 AM
  2. audi a4 1995 - door and boot lock required
    By gazzy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-07-2013, 09:35 AM
  3. CCM changed now door lock microswitches have swapped... code required !
    By Golf tdi Hal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-04-2013, 12:42 PM
  4. front passanger door handle not opening door?
    By fabusy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-01-2011, 11:34 PM
  5. Faulty lock and passanger window
    By mattjc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 01:06 PM
