Thread: 98 a8 d2 2.8 coolant tank with chocolade but diptick and oil cap is clean
  1. Question 98 a8 d2 2.8 coolant tank with chocolade but diptick and oil cap is clean
    Nov 2015
    GB, SOMERSET, TAUNTON
    HELLO TO ALL AFFECTEC BY AUDI ADICTION. IM NEW HERE. I GOT NEW TOY, BUT WITH LITTLE PROBLEM. AS STATED IN TITLE WHAT MAY BE CAUSINMG THIS?
    LAST OWNER SAID IS NOT OVERHEATING AND NOT LOOSING COOLANT, MYSELF HAVD NO TIME TO INVESTIGATE TODAY. ITS MY FIRS A8 D2 AND V6 SO I KNOW NOTHING.
    ALL HELP WILL BE APRECIATED. HOW QUICKEST WAY TO DIAGNOSE HEAD OR HEADGASKET CRACK WITH BASIC TOOLS?
  2. Re: 98 a8 d2 2.8 coolant tank with chocolade but diptick and oil cap is clean
    Jul 2015
    Staffs
    46 Post(s)
    Why not flush the engine coolant, clean the tank and replace with correct grade?
    There's no quick way to diagnose head gasket issues. Being unfamiliar with the engine maybe research a failed oil cooler if it has one??
    Also turn off your cap locks
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: 98 a8 d2 2.8 coolant tank with chocolade but diptick and oil cap is clean
    Oct 2014
    TAUNTON . SOMERSET
    Hi. Yes I will change oil cooler first as it's cheapest part in this investigation. Just waiting for gasket from audi. To flush cooling system I do not have access to water hose, so will fill with water and run it drain it and repeat it few times.
    Sent from my E6853 using Tapatalk
  1. coolant res tank FULL of oil !
    By Passat2003 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-05-2016, 01:10 PM
  2. Pressure in the coolant tank
    By Rayscriv in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-11-2014, 11:36 PM
  3. oil in coolant tank
    By huyton1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-08-2009, 11:50 PM
  4. Question oil in coolant tank?
    By huyton1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-08-2009, 04:27 PM
  5. Pressurised Coolant tank
    By patzer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-07-2008, 08:35 PM
