Thread: Clutch pedal sticking down
  1. Clutch pedal sticking down
    Sep 2007
    I have a 2012 Audi A3 TDI S Line Quattro 170. I had a problem with the clutch pedal sticking down and the mechanic changed the master cylinder and the slave cylinder and I put a new clutch and flywheel in as recommended. It’s all working again now but when the car is left all day or over night when I go to start it the pedal sticks down but if I pull it back up after it starts it works fine. It’s been back to get bled again but it was the same again the next morning. Any ideas. Someone mentioned that there’s another valve like a non return or something like that and this may need changing. It’s only cheap apparently ?
  2. Re: Clutch pedal sticking down
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Did you fit the correct clutch plate, cover, bearing and flywheel? This may be the issue if any of them are the incorrect part for your car.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Clutch pedal sticking down
    Sep 2007
    I hope so he is a German car specialist. It’s started to leak now somewhere on the drivers side so it’s gone back in
  4. Re: Clutch pedal sticking down
    Nov 2008
    20 Post(s)
    Okay. I ask as Ive had an incorrect clutch kit for a merc sprinter and although looking at it it looked identical it had all manner of issues when in operation! It was from a main dealer too!Possibly the leak is the problem.
    Alan.
  5. Re: Clutch pedal sticking down
    Sep 2007
    He’s changed something underneath the battery tray that was leaking a valve or a cylinder. Car feels much better now just hope it’s ok
  1. sticking clutch pedal
    By WillUK in forum Touran - Sharan - Caravelle
    Last Post: 19-02-2015, 11:05 AM
  2. Please Help Golf MK 5 sticking clutch pedal
    By Cheshire_cab in forum Golf MK5 - 2004 - 2009
    Last Post: 30-09-2010, 11:18 AM
  3. Please Help a3 sticking clutch pedal
    By karl150 in forum Audi A3 - Archive Topics
    Last Post: 23-02-2009, 11:01 PM
  4. Sticking clutch pedal
    By zuffler in forum Audi A3 - Archive Topics
    Last Post: 18-02-2008, 10:45 PM
  5. Sticking Clutch Pedal
    By Sesame in forum Passat - Archive Topics
    Last Post: 31-05-2006, 11:39 PM
