Thread: Engine oil level problem?
Results 1 to 10 of 10
  1. Engine oil level problem?
    Mar 2018
    London
    hi everyone,
    I've done a service on my A6 3.0L tdi quattro and for some unknown reason it's not taken the 8.2 litres of oil as per manual.
    i put roughly 7 litre in, started the car to let the oil filter
    fill up, then i topped up the oil to near the max mark on dipstick.
    overall i used 7.5 litres.
    i thought that after a few miles i would have to top up, instead after 3 days the level is still ok.
    am i missing something or i made a mistake somewhere?
    i have taken out just over 8 litres, so i don't know what's happening.
    Didn't flush engine with anything and drained oil from the sump until last drop.
    And yes, i took the filter out and let drain.
    thanks for any input.
  2. Re: Engine oil level problem?
    Feb 2016
    London
    13 Post(s)
    Which manual did you get the 8.2L figure from? My 3.0L TDI takes 7.3L according to the handbook and this always hits the mid point on the dipstick but my mechanic has a service database that says 8.2L so perhaps different years had slightly different sump capacities? If in doubt I'd go with the dipstick reading.
    2011 A6 Allroad 3.0TDI
  3. Re: Engine oil level problem?
    Mar 2018
    London
    Hi, i got the info fro the manual that came with the car.
    All other services done by Audi are showing 8.2 litres as well.
    I know that it doesn't mean they actually put that much, but i also measured what it came out and it's just over 8 litres.
    I'm going by the dipstick and with 7.5 litres is showing near the max mark.
    Mistery.
  4. Re: Engine oil level problem?
    Feb 2016
    London
    13 Post(s)
    What year is your car?
  5. Re: Engine oil level problem?
    Mar 2018
    London
    March 2008
  6. Re: Engine oil level problem?
    May 2008
    40 Post(s)
    Dont forget quoted figures will be a dry fill ie a new virgin engine, when you drain/refill its impossible to get it all out hence you can only get 7.5 back in.
    It doesnt have to be on the max, mark towards the top end is just fine.
    Just checked notes in wifes book and Ive written 7.75 litres for her 3.0tdi 2011 model.
  7. Re: Engine oil level problem?
    Jul 2008
    Lisburn
    15 Post(s)
    Prob got 8 out as the last person measured it in rather than check?
  8. Re: Engine oil level problem?
    Mar 2018
    London
    Ok, thanks for all the input.
    I checked again today and it's still a couple of mm below max, so all good.
    Audi serviced this car from new, i would assume they know what they're doing (or maybe not ��)
    Strange thing is that i always keep an eye on the oil level nd before changing it it was just below the max as always.
    Took out just over 8 litres and 7.5 went back to the same level.
    Mistery!
  9. Re: Engine oil level problem?
    May 2008
    40 Post(s)
    Assuming you poured it straight in from the jug the oil came in? if so maybe they were slightly overfilled? so 4 litre was actually 4.1 or 4.2.
    Ive seen a few main dealer vehicles overfilled with oil.
  10. Re: Engine oil level problem?
    Mar 2018
    London
    I poured 5 litres from the oil container it came in and another 2.5 from the second one.
    I doubt they give you more than stated on the label.
  1. Please Help Oil Level Sensor Failure 170 (BRD engine)
    By sanstorm999 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-04-2015, 09:33 PM
  2. Question Engine Oil Level light (and others)
    By benmo in forum Jetta MK3 - 2005 - 2013
    Last Post: 05-02-2014, 11:33 PM
  3. Engine Oil Level Warning
    By acmo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-05-2012, 06:59 PM
  4. Question A4 B8 Problem of Oil Level Display in MMI
    By nordi33 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-02-2009, 12:30 PM
  5. engine oil level
    By audi-nutz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-01-2008, 04:04 PM
