Thread: engine problem
  1. engine problem
    Aug 2014
    uk
    have a 2005 3 cylinder polo, just bought it yesterday! as i drove away i put the foot down and the eml came on and it wouldnt rev past 2000 rpm, managed to drive it a couple miles taking it easy. stopped, restarted and it drove 18 miles no problem at all with no light on.
    ive attached a file of the fault codes. i cleared the faults, let it idle and took it for a quick drive and no codes returned. i also swapped cylinder 1 and 3 plugs and pencil coil.
    codes havnt returned yet but it sometimes cuts out when stop at junction or if i rev it hard the revs either drop to around 300rpm then recover or it cuts out.
    any helps appreciated, thanks
    edit: it has a fair bit mot, but the previous owner did mention that the mot tester said it will need a cat for next mot, the emmisions do smell rich
  2. Re: engine problem
    Jun 2016
    Glasgow
    Coil pack be first thing to check.
    Swap out 3 with 1, clear codes, start engine, recheck for codes. If fault follows cylinder, renew coil as required.
  3. Re: engine problem
    Aug 2014
    uk
    ok thanks mate
  1. Help! 1.8t engine problem (stuck engine)
    By coyleben in forum 1.8T - Engine
    Last Post: 17-09-2010, 01:08 AM
  2. Please Help Engine problem
    By bow999 in forum Golf MK4 - 1999 - 2004
    Last Post: 08-11-2009, 07:06 PM
  3. Question Engine problem - Engine speed sticks high / Unstable engine speed
    By sef-75 in forum Bora - 1998 - 2005
    Last Post: 29-09-2009, 09:52 PM
  4. engine problem
    By willow24 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-01-2008, 12:53 AM
  5. problem with my a4 1.8 adr engine
    By philg in forum New Member Introductions
    Last Post: 02-11-2007, 08:17 PM
