Thread: Reduce oil???
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Reduce oil???
    Apr 2017
    London UK
    10 Post(s)
    Hi, Iíve searched for this but not found anything so apologies if it has come up already. My Q7 has started showing a reduce oil level message, though no oil has been added for some time. Is this just likely to be a fault with the sensor? Has anyone else had this issue? Thanks.
  2. Re: Reduce oil???
    Jan 2016
    Co Durham
    15 Post(s)
    If you have milage and how you drive you may get a more informed reply. I used about 1lt in 7000 miles but I did short journey driven in quite a sympathetic manner.
  3. Re: Reduce oil???
    Nov 2010
    Shetland & S.Tyneside
    103 Post(s)
    I've seen this high oil level on a BMW, it could be the same in your case; if you do shorter trips with engine not getting fully up to heat and active dpf regens the change in diesel injection timing ( injecting diesel on exhaust stroke I think) can end up washing down cylinder walls into the sump and dilute oil and raising level.
  4. Re: Reduce oil???
    Jan 2016
    Co Durham
    15 Post(s)
    Sorry I read it as reduced oil. A trip to the dealers me thinks.
    Quote Originally Posted by DL78 View Post
    Hi, I’ve searched for this but not found anything so apologies if it has come up already. My Q7 has started showing a reduce oil level message, though no oil has been added for some time. Is this just likely to be a fault with the sensor? Has anyone else had this issue? Thanks.
  5. Re: Reduce oil???
    May 2012
    Somerset
    242 Post(s)
    More common sense marques have an injector post engine to heat up the dpf .
    What we're the others thinking...
  6. Re: Reduce oil???
    Nov 2014
    Nottinghamshire
    Had it on my SQ the other week. Did some searching and probably being caused by doing short runs - or not enough longer runs. I took mine out for an hour and the warning remained on, but when I got back in after an hour or 2 it went off and has not been on since. Mine's not had any oil in since new. Only done 8k miles though
  7. Re: Reduce oil???
    Nov 2010
    103 Post(s)
    Fuel dilution of oil reduces viscosity and accelerates engine wear, another good reason not to leave oil change services to 20,000 miles.
  8. Re: Reduce oil???
    Apr 2016
    Stansted
    169 Post(s)
    Iíve just started getting this warning. Will try and get a long run in this week to see if it goes away!
    Former Q7 owner
  9. Re: Reduce oil???
    Nov 2014
    Nottinghamshire
    Quote Originally Posted by srbsq7 View Post
    Had it on mine a few times. I reckon it's low usage, or seemed to be the case with mine. I have now swapped the SQ7 over to a Q8 3.0 and not had it on this one - yet!
  10. Re: Reduce oil???
    Jan 2020
    York
    Have you tried opening and closing the bonnet know it sounds daft but has worked sometimes there is a software upgrade also if you donít have a dipstick you can get them of amazon and not mega expensive always a good buy for piece of mind.
  1. Question Please reduce engine oil - NIGHTMARE
    By Pete_NorthEast in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-02-2018, 10:44 AM
  2. Please reduce engine oil
    By Redcar01 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 23-02-2016, 06:39 PM
  3. Reduce oil warning
    By DrNorthy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-03-2014, 11:34 AM
  4. Please Help Must reduce HC emissions
    By glenoaks in forum Chat - Anything with wheels
    Last Post: 22-10-2009, 06:28 PM
  5. Reduce emissions
    By cbrpaul in forum VCDS - General Questions
    Last Post: 05-05-2008, 02:47 PM
