Thread: Please help DPF problem
  1. Please help DPF problem
    Mar 2018
    huddersfield
    Hi folks, Hope you can help me.
    Audi a3 2010 2.0 tdi 140 (cffg) 53k on the clock that I have owned for 7 years has amber dpf symbol lit up. I took the car up to the motorway and there seemed to be a delay of throttle response and then kicked into life intermitenly. before I got to motorway coil light started flashing and no luck with regen.
    I hooked up snap-on solus, just soot build up fault code. I tried static regen but didn't get anywhere near 1500rpm after 30mins. I took the car back on motorway with dynamic driving regen mode. after several attempts I got the same:
    status active
    soot level 5g at 2000rpm
    temp before dpf 180-230 deg
    temp after dpf 150-160 deg
    I took the revs upto 3600 rpm for 10mins in 3rd just to see temp level before dpf and only got to 280 deg, no where near the regen temp.
    i've tried every option possible and I feel the regen is not possible with coil light flashing?
    could MAF cause this?
    throttle assembly looks fine very little build up.
    hoping not to go down the line of new dpf turbo etc as was changing car come April
    TIA
    Paul Thornton
  2. Re: Please help DPF problem
    May 2012
    Everywhere
    308 Post(s)
    Welcome to the DPF merry-go-round .
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Replies: 19
    Last Post: 24-12-2011, 09:45 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
