Thread: alternator
Results 1 to 10 of 14
  1. alternator
    Jun 2009
    uk
    hi
    got a audi a4 b6 2001 recently the alternator just died out on me got a replacement from a breakers got mechanic to fit but its making a really loud grinding noise when on full lock.
    contacted breakers and they sent me another one but this one is a 120 amp alternator mines is 140 amp will this be ok or will i have problems powering things up??
    thanks
  2. Re: alternator
    Nov 2010
    Shetland & S.Tyneside
    102 Post(s)
    Are you sure its not the power steering pump grinding on full lock. I would reckon 120 A would be ok.
  3. Re: alternator
    Jun 2009
    uk
    Only started making that noise when the alternator was fitted mechanic said it's the alternator to.
  4. Re: alternator
    Nov 2010
    102 Post(s)
    OK fair enough - just seems odd that the alternator reacts to steering lock, I was thinking that the belt is now tighter since the replacement alternator has been fitted and the extra belt tension is making the steering pump complain when it is loaded up.
  5. Re: alternator
    Dec 2016
    Chattanooga, TN, US
    If it's a 1.8 b6 with the two front and 2 rear side mounted bolts, it alternator will mount upside down. Mine was a Valeo I picked up at a parts store and the connectors in the back were 180 degrees from my original. I mounted it oriented with the original connector, seemed like it took a bit more torque to get it all flush than it should have. Sure enough, pull had resistance. Took it off and the pully turned smooth again, flipped it over and mounted it, problem solved.
    Sent from my SM-G955U using Tapatalk
  6. Re: alternator
    Jun 2009
    uk
    looks like to much messing around will just tell the breakers yard give me a refund to much messing around paying labour twice.
  7. Re: alternator
    Dec 2016
    Chattanooga, TN, US
    If they installed it upside down you shouldn't have to pay labor again... Or just do it yourself. Takes about 25 minutes for longitudinal engine (belt facing front of the car). Remove the coolant reservoir, the top radiator hose, put a 17mm wrench on the belt tensioner and pull to the right to release tension and slip the belt off. Remove the 4 12mm bolts, pull the alternator out, remove the 10mm nut and cable from the back of the alternator, remove the harness that's clipped in and flip it over. Reverse the steps to remove it. Several good YouTube videos on the subject and all it takes is a basic socket set, torx keys and a 17mm wrench. I took off the throttle body (4 hex key bolts) and went ahead and replaced them with hex head, so they're less likely to strip.
  8. Re: alternator
    Sep 2008
    chester
    15 Post(s)
    Its the clutch pulley on the alternator swap them over.
  9. Re: alternator
    Jun 2009
    uk
    thanks for advice just ordered a socket set from Amazon these alternators that first choice sent me look worse for wear and in worse condition then my original valeo alternator that was on.
    is it easy to replace the pulley on the bosch now i can feel the vibration on full lock is it the pulley or the bearings causing this noise??
    thanks
  10. Re: alternator
    Jun 2009
    uk
    Quote Originally Posted by cyl.mischief View Post
    the 120 amp alternator is the wrong one thats not fitted yet the bosch one they sent me is the right one but making a loud humming noise
  1. Question Would a failed alternator clutch pulley damage alternator shaft?
    By diyjack76 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-05-2015, 02:11 PM
  2. Query alternator woes, second opinion please - Battery light, alternator
    By mebedforduk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-05-2014, 12:54 PM
  3. Please Help Alternator belt tensioner + Alternator clutch pulley - time and money?
    By Cliveski in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2013, 02:25 PM
  4. Replies: 4
    Last Post: 04-01-2013, 03:51 PM
  5. Replies: 2
    Last Post: 14-06-2011, 04:18 PM
