Thread: Door warning, and ground lighting not working
  1. Door warning, and ground lighting not working
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    I've just noticed my 2014 3.0 Quattro s-line has the red 'door open' warning lights, and the ground illumination lights under the doors, but none are working. On my C5, these and footwell illuminators came on when the door was opened.
    I'm assuming there is a coding in the central convenience module that's been set wrong, and/or it's been turned off?
    I can't find anything in the handbook regarding these....
    Anyone got any ideas?
    Cheers!
  2. Re: Door warning, and ground lighting not working
    Mar 2014
    Edinburgh
    235 Post(s)
    Have you check the bulbs or fuse isn’t blown?
  3. Re: Door warning, and ground lighting not working
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Not checked anything yet, I assumed as nothing works, and the car is very low mileage, it was a settings issue. Could be a fuse, but chances of every bulb blown unlikely.
    However, I have been Googling this, and other older Audis with this problem have dummy reflectors fitted, but no wiring or bulbs. They need the lighting pack fitted to work. Saying that, I would expect a 2014 s-line to have all this as standard?
  4. Re: Door warning, and ground lighting not working
    Jan 2016
    Merthyr Tydfil
    25 Post(s)
    I suspect they are dummy reflectors. Easy enough to pop out and check using a flat head screwdriver
    its an Audi - you expected this to be standard??
  5. Re: Door warning, and ground lighting not working
    Mar 2014
    Edinburgh
    235 Post(s)
    I thought they all had lights and the lighting/ambient pack gave you leds instead old fashion halogen type bulbs.
  6. Re: Door warning, and ground lighting not working
    Apr 2009
    Surrey
    171 Post(s)
    As standard on the A6 (pre and post facelift) you get passive red reflectors and puddle lights for the front doors only. The Lighting Package adds illumiated red lights (and I think puddle lights for the rear doors). As others have said don't expect too much as standard on an Audi!
  7. Re: Door warning, and ground lighting not working
    Mar 2014
    Aylesbury Bucks
    19 Post(s)
    Quote Originally Posted by johnsimcox View Post
    Yes, that seems like what I have. The rear puddle lights are not even blanked, they just haven't been punched out of the door cards. All 4 doors have red reflectors, and all 4 footwells have lights. (hadn't notice these due to interior lighting!)
  1. Low battery warning and passenger door not working
    By C Mitchell in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2013, 01:02 PM
  2. Door Handle Touch Sensor (G418) 007 - Short to Ground
    By 66Cobra in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 28-03-2012, 07:38 PM
  3. Please Help headunit not working after touching live and ground together accidentally :(
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-07-2011, 12:18 PM
  4. Please Help Boot lighting and door lights not working
    By TDi_SE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-10-2010, 01:05 PM
  5. Door warning lights...not working
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-06-2008, 07:41 PM
