Thread: Key not recognised.
  1. Key not recognised.
    Hi All,
    Grateful for some advice if possible.
    I have an Audi A6 C7 MY2012 3.0TDI Quattro - had front tyres changed a couple of days ago.
    After driving a few miles - got tyre pressure low warning, fine I thought my fault for not resetting tyre pressures.
    Another couple of miles - Fault stop start system.
    Pulled into petrol station and filled with fuel and reset the tyre pressure system.
    Then when tried to start - key not recognised hold to dash or equivalent.
    Since then no warning lights or faults on the DIS but key consistently not recognised to start car.
    Have replaced batteries on both main and spare which both open the car and the boot but will not remotely start without holding at dash.
    Also checked on MMI still has 3 keys initialised.
    Before going down route of dealer - anyone any ideas on this?
    The stop start although no fault showing on system has also stopped I assume this is due to the key issue as it would not restart.
  2. Re: Key not recognised.
    Mar 2014
    Edinburgh
    219 Post(s)
    I had something similar with my keys.
    I bought some batteries at Tesco and after a few weeks it did the same thing so splashed out Duracellís at £5 a pop and itís worked for a few months. Put it down to cheapy batteries.
    Yours might be a receiver/aerial type problem as I couldnít even unlock the doors after a few weeks.
    Better batteries is worth a try as itís cheap cause a dealer will charge £50-100 for diagnostic
  3. Re: Key not recognised.
    Unfortunately replaced both batteries with new Duracells - also car opens and closes normally as does the boot.
    Either the key receiver has a problem or somehow it needs reinitialised?
  4. Re: Key not recognised.
    Mar 2014
    Edinburgh
    219 Post(s)
    Itís sounding more and more like an aerial or receiver for the immobiliser not working well or is not getting enough power.
    Essentially the bit where you hold it against the dash is the old immobiliser receiver ring that you get with cars that uses keys to start. If thatís not getting a signal or a confused signal then itís not gonna work.
    It could also be interference from something. My old work put up a mobile mast in the car park and non of my car remotes worked unless I had it next to / against the drivers window.
  5. Re: Key not recognised.
    Dec 2015
    London
    13 Post(s)
    Had the exact same problem (would open/lock the car etc but msg when trying to start 'key not recognised' so had to hold key next to the designated area on the dash to start) with one of my two keys when I bought the car (used, from Audi).
    The bad news potentially is, They had to order and replace the key to resolve.
  6. Re: Key not recognised.
    glasgow
    34 Post(s)
    try the spare key !!
    if you have the same problem on spare key ....................................... then its not the key
  1. Myaudi PIN not recognised by the car
    By Speedbird1300 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 02-04-2017, 11:52 AM
  2. Please Help Cd failed to be recognised
    By mistermoo in forum In Car Entertainment
    Last Post: 01-09-2015, 09:15 AM
  3. New (to me) A6 C7 - Spare key not recognised / initialisation help
    By driventodespair in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-01-2015, 11:05 PM
  4. CD magazine not recognised?
    By Timbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-09-2010, 08:21 AM
  5. Key not recognised
    By Margo in forum Golf MK3 - 1993 - 1999
    Last Post: 17-02-2008, 04:42 PM
