Thread: Rear End Banging over uneven Ground
  1. Rear End Banging over uneven Ground
    Jun 2009
    Telford UK
    Hi All
    Daughters car is showing signs of a rear banging noise over pot holes ect
    Had a look at the usual and nothing obvious except ....
    Bounce the rear of the car with hand brake off and in gear and O/S rear metal screetching noise
    Bouncing the car while holding the spring is not good as it feels like its juddering while making a noise
    Spring looks fine and spacing looks equal compared to the Passenger but it don't feel good ...
    Can't see the bottom of the spring as it hides in the rear wish bone but does any one have any ideas
    I'm thinking the bottom of the spring has snapped
    Wheel bearing feels fine - roll bar and drop links looks fine
    She does say its sounds better with the tank full of fuel
    Any thoughts
  2. Re: Rear End Banging over uneven Ground
    Jan 2018
    Yorkshire
    7 Post(s)
    Have you jacked car up as high as possible to see if spring has actually snapped?
  3. Re: Rear End Banging over uneven Ground
    Jun 2009
    Telford UK
    Hi Mick
    Yes when I checked the wheel bearing for play
  4. Re: Rear End Banging over uneven Ground
    1840 Post(s)
    Golf 5/6 rear springs often snap at the bottom where you can’t see them and the broken bit bounces around inside the spring arm making a terrible racket.
  5. Re: Rear End Banging over uneven Ground
    Jun 2009
    Telford UK
    On form again... Cheers
    One spring snapped in two places at the bottom and the other was fine
    Both springs replaced in 1 hour with a pair of Sachs for £35 each
    Remove bolt from bottom wish bone to hub and then spring comes out easy with no spring clamps
    This is one of the easiest jobs under your car you can do on your drive with a few tools
  1. Please Help Mysterious heavy bump/thump from rear when travelling over uneven ground
    By redser in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-09-2015, 03:41 PM
  2. Loud crack, now rattle over uneven ground
    By chips in forum Alhambra
    Last Post: 23-06-2013, 01:39 PM
  3. Uneven rear tyre wear
    By magebora in forum Bora - 1998 - 2005
    Last Post: 12-01-2011, 11:06 PM
  4. rear pads worn down uneven
    By eddieace in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-03-2009, 02:50 PM
  5. Steering wants to go it's own way on uneven ground!
    By Dudey Head in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 29-07-2008, 02:04 PM
