Thread: Low oil Pressure
  1. Low oil Pressure
    Mar 2018
    GB
    bought a car yesterday. test drive everything seemed ok. engine was noisey. but apart from that nuthung untoward.got half way home and low oil pressure STOP flashed up. and I mean flashed before I had chance to stop it went off again. I drove carefully home. and noticed it is mostly when turning Hard ie roundabouts and junctions any ideas anyone. I'm new to golf world I don't really understand why it comes and goes... any help or advise would be great. btw it is a 2004 2L GT fix done 126000
  2. Re: Low oil Pressure
    Jul 2015
    Staffs
    44 Post(s)
    What was the oil level? Petrol? Engine code?
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Low oil Pressure
    Nov 2010
    Shetland & S.Tyneside
    81 Post(s)
    If it comes on when going round bends or braking it could be low oil level sloshing about and pickup losing suction - check oil level. also could be blocked pickup strainer or knackered oil pump drive key if its a 2L diesel.
  4. Re: Low oil Pressure
    Mar 2018
    GB
    Quote Originally Posted by rowdy-999 View Post
    well I checked it this morning seems a good level. could the wrong oil have same effect.. it's a petrol. not sure of engine code where can I find it?
  5. Re: Low oil Pressure
    May 2012
    Somerset
    152 Post(s)
    Engine code ?
  6. Re: Low oil Pressure
    Nov 2010
    81 Post(s)
    Sticker in the spare wheel well and in the front of the service book
    Quote Originally Posted by scottweight.91 View Post
  7. Re: Low oil Pressure
    12 Post(s)
    251 Post(s)
    These engines are prone to oil pressure problems due to sump sludge, it will be an AXW engine, a bit of a rare car, I have only ever come acrosss a few. They can also suffer problems with the balancer shaft assembly but it is not a common problem as it is quite different to the system on the 2L TDI units where one is used. I suspect it is why the car was sold and my advice would be to have the sump removed and checked for sludge and then a proper oil pressure test carried out which must show at least 2Bar at 2000 rpm @ 80 degrees oil temp but 3Bar is the lowest I like to see with hot oil.
    Quote Originally Posted by Rob69 View Post
    The Golf 5 2L TDI with the BKD engine does not use a balancer shaft
  8. Re: Low oil Pressure
    May 2012
    Somerset
    152 Post(s)
    It's a 2L petrol Steve so a chain drive oil pump tensioner issue.
  9. Re: Low oil Pressure
    12 Post(s)
    251 Post(s)
    If the car is what I think it is, a 2004 model year only manual 2L 16v FSI then the car will be a type 1K1 2N2 with the EA113 series AXW code engine which uses a chain driven balance shaft system with a chain driven Gerotor oil pump.
  1. Low oil pressure
    By tonytom in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-03-2014, 12:45 PM
  2. Oil pressure on a 1.8t
    By Andy1.8tQuattro in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-08-2013, 12:24 AM
  3. Oil pressure?
    By danny_boy4 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-08-2012, 07:01 PM
  4. Please Help Oil pressure???????????
    By matt_80 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-01-2010, 07:42 PM
  5. oil pressure
    By vanmanfrisko in forum The Commercial Range
    Last Post: 27-07-2009, 10:24 AM
