Thread: oil in coolant even after oil cooler change, tdi 170 BMN
Results 1 to 10 of 14
  1. oil in coolant even after oil cooler change, tdi 170 BMN
    Mar 2018
    wales
    i had oil in my coolant bottle so i changed the oil cooler, flushed the system quite a few times. every day after doing my daily 70 mile trip i would remove the bottle and clean it. decided to leave it for 3 days without cleaning it and the coolant light came up again. checked the bottle and there was oil in it again. what else could it be, head gasket? ive got no other signs of a head gasket thats gone. no trouble starting it in the morning and definetly no oil getting into the engine at all. everything ive read up on the BMN engines with coolant and oil mixing is a failed oil cooler and alot of failures in the head cracking causing coolant loss but im gaining oil not loosing coolant.
  2. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    1840 Post(s)
    This could be a head gasket issue, the BMN has been known to suffer cracking problems around the head gasket dowels which can cause oil to get into the cooling system, there is a VAG TPI about this issue.
  3. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    Mar 2018
    wales
    ive read that the early heads were prone to cracking but i though they fixed that issue with the newer heads? sorry to sound dumb but what is a TPI?
  4. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    Mar 2018
    wales
    sorry should have mentioned mine is a 58 plate tdi
  5. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    1840 Post(s)
    Technical Product Information notice. The early head cracking issue you know of could be the port issue where water would get into the inlet ports overnight, the gasket dowel issue was different and did not require a new head or block, there is a procedure for repair with the head removed which I have at work, I don’t have ELSAwin at home now as I was getting stick for “working” at home so I can post the TPI on Monday if you remind me.
  6. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    Mar 2018
    wales
    ok thanks. ill inbox you on monday then
  7. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    Mar 2018
    wales
    Hi crasher. Any chance you'd be able to look up the tpi today? I've checked the head number and mine is a C
  8. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    Aug 2018
    Belfast
    I have the same issue my mechanic wants me to change the engine as he thinks replacing the head would cost the same buy the time you buy second hand head a send it off to get checked and might not be a good one don't know what to do??
  9. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    1840 Post(s)
    Where are you going to find a decent warranted low mileage BMN? The youngest is a decade old and they were rare in the first place.
  10. Re: oil in coolant even after oil cooler change, tdi 170 BMN
    Oct 2017
    London
    12 Post(s)
    I’ve just changed a failed BMN in an 08 Touran 170 and replaced it with a BMR and have exactly the same issue. Would the next step be a head gasket change?
  1. Coolant leak by diesel cooler - arl 150
    By M53494 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-10-2015, 08:50 PM
  2. Oil in Coolant - Already Changed Head, Oil Cooler, etc etc
    By jwalman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-03-2014, 02:45 PM
  3. Please Help Any Other ideas? Oil in coolant after new oil cooler and head gasket
    By Mikeybs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-04-2013, 10:44 AM
  4. oil still in coolant bottle after oil cooler replacement
    By biggs001 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-02-2010, 11:06 AM
  5. Question 1.8T Oil, oil cooler change and coolant replacement
    By Entropy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-08-2009, 03:26 PM
