Thread: VW Golf MK7 stop start not working - VCDS report missing ABS controller missing messages
  1. VW Golf MK7 stop start not working - VCDS report missing ABS controller missing messages
    Aug 2016
    Out of the blue at the end of 2017 my stop start stopped working. I initially thought the stop start wasn't working as a result of low tyre pressure. However, the problem has persisted. Could anyone please advice on how to fix this issue?
    Code:
    Code:
    Sunday,14,January,2018,11:47:48:64250
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 17.8.1.0 (x64)
    Data version: 20171130 DS276.6
    www.Ross-Tech.com
    VIN: xxx License Plate: yyy
    Mileage: 149828km-93098mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
    VIN: xxx Mileage: 149828km-93098miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    15-Airbags -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H83 4943
       Revision: 00H83H22
       Coding: 011D0012036505083000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
       ROD: EV_ECM20TDI01104L906021DT_002.rod
       VCID: 7AF1E804FD25A396DF-802E
    3 Faults Found:
    5290 - Throttle Actuator Control Circuit
              P2100 00 [104] - Open Circuit
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 6
                        Mileage: 148256 km
                        Date: 2017.12.15
                        Time: 08:49:38
                        Engine speed: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 15 °C
                        Intake air temperature: 10 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 12.680 V
                        Unlearning counter according OBD: 40
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 100.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.02 %
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 0: 0
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 16: 9
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 24: 55
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 8: 2
                        Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4506.2 mV
    20558 - Heater Support Pump
              P16C6 00 [032] - Running Dry
              Intermittent - Not Confirmed - Tested Since Memory Clear
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:55
                        Engine speed: 871.50 /min
                        Normed load value: 22.7 %
                        Coolant temperature: 80 °C
                        Intake air temperature: 66 °C
                        Ambient air pressure: 990 mbar
                        Voltage terminal 30: 12.100 V
                        Limitation: accelerator pedal: 0.0 Nm
                        CAN status - engine control module-Bit 0: 0
                        Cruise Control System (CCS): status-Bit 0: 1
                        CAN status - transmission control module-Bit 0: 0
                        CAN status - brake control module 1-Bit 0: 0
                        CAN status - brake control module 2-Bit 0: 0
                        selected gear-Bit 0: 0
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
       Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
       Component: DQ250-6F MQB  H52 3613
       Revision: 05652103    Serial number: TFK01302020099
       Coding: 0014
       ASAM Dataset: EV_TCMDQ250021 001001
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 152BDBB8F47B6CEE52-8040
    1 Fault Found:
    10763 - Starter Enable from Selector Lever Sensor System
              P1734 00 [002] - -
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
       Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
       Component: ESC           H75 0537
       Revision: 00000000    Serial number:
       Coding: 01FA8AA120210A6F037D060301C92980510450C0608094F3F86A5028C1
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7EF9E414E10D8FB6E3-802A
    3 Faults Found:
    8192 - Databus
              U1121 00 [137] - Missing Message
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:55
    8196 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:55
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 71
                        Reset counter: 191
                        Mileage: 149134 km
                        Date: 2017.12.30
                        Time: 11:07:06
    Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
       Part No SW: 5Q0 959 435     HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0500
       Revision: 00021000    Serial number: 0206610423
       Coding: 030C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002011
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 79F3F708F823A88ED6-802C
    No fault code found.
    Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
       Part No SW: 5G0 907 426 K    HW: 5G0 907 426 K
       Component: AC Manuell    H01 0503
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_002_VW37.rod
       VCID: 336F05209ACF92DE5C-8066
       Fresh Air Blower Front:
       Refrigerant Pressure And Temperature Sender:
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011306001655
       Coding: 03011846C241027B0FA44080B11C0728180A000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 010001
       ROD: EV_BCMBOSCH_010.rod
       VCID: 46894CF4F95D1776EB-8012
       Control Unit For Wiper Motor:
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    130217  042 0551
       Serial number:         130222072350
       Coding: 0E4DD5
       Rain Light Recognition Sensor:
       Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
       Component: RLS  024 0042
       Serial number: Y13M02D22H07M39S40S1
       Coding: 00A8DD
       Sensor For Anti Theft Alarm System:
       Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY130382NFG
       Alarm horn:
       Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Component: Sirene, DWA  004 0311
       Serial number: 00000000000056047921
    3 Faults Found:
    204546 - Remote key 2
              B147A 18 [009] - Current Too Low
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 133
                        Mileage: 148128 km
    539925 - Databus
              U1121 00 [008] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 157
                        Mileage: 149005 km
                        Date: 2017.12.26
                        Time: 18:20:02
    934149 - Rain/light recognition sensor
              B1366 76 [008] - Wrong mounting position
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 175
                        Mileage: 149395 km
                        Date: 2018.01.05
                        Time: 10:03:38
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  002 0026
       Revision: --------    Serial number: 94231305500207
       Coding: 0071051011
       ASAM Dataset: EV_EPHVA18AU3700000 002016
       ROD: EV_EPHVA18AU3700000_002_VW37.rod
       VCID: 3A712804BDA563969F-806E
    Address 13: Auto Dist. Reg
    Cannot be reached
    Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Component: AirbagVW20    011 0361
       Serial number: 003M1R01YHGZ
       Coding: 98CCC000000000005C0000CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X_VW37.rod
       VCID: 4A9178C4ED45F3160F-801E
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169677A01031340101
       Coding: 333135
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676A01031370178
       Coding: 333135
       Side Sensor Driver Front:
       Subsystem 3 - Part No SW: -----------    HW: 480 002 202 13
       Component: SideSensor_Df  001 0887
       Serial number: 3576700000059B28DC02
       Coding: 2D2D2D
       Side Sensor Passenger Front:
       Subsystem 4 - Part No SW: -----------    HW: 480 002 202 13
       Component: SideSensor_Pf  001 0887
       Serial number: 3586700000075B113C0Q
       Coding: 2D2D2D
       Side Sensor Driver Rear:
       Subsystem 5 - Part No SW: -----------    HW: 480 402 502 13
       Component: SideSensor_Dr  001 6149
       Serial number: 3516502AD0F8ABF2510Q
       Coding: 2D2D2D
       Side Sensor Passenger Rear:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 502 13
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502A90F8ABF4C27/
       Coding: 2D2D2D
       Front Sensor Driver:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 602 13
       Component: FrontSensor_D  001 6149
       Serial number: 3556502BF0F7B8E39291
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
       Component: Lenks. Modul  007 0070
       Revision: --------    Serial number: 25021308490526
       Coding: 0C00
       Shop #: WSC 40195 333 37120
       ASAM Dataset: EV_SMLSKLOMQB 009001
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 020190E495F5EB5687-8056
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
       Part No SW: 5G0 920 960 A    HW: 5G0 920 960 A
       Component: KOMBI         236 0555
       Coding: 27A401182780260001886A01040000
       ASAM Dataset: EV_DashBoardVDDMQBAB 008026
       ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
       VCID: 2757E1705E17EE7EF0-8072
    3 Faults Found:
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:46:00
    16776960 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:54
    16776961 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:54
    Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000384787
       Coding: 030100040B087300EF00045C1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 346D063C9FC195E645-8060
       Alternator:
       Multi Function Steering Wheel Control Module:
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H12 0034
       Serial number: 02120004537170090291
       Coding: 2D0000
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Component: J367-BDMHella  H03 8042
       Serial number: 8020799101
    1 Fault Found:
    66054 - Extended CAN Bus (SAE Bus C)
              U0047 00 [009] - Performance
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:58
                        Supply voltage: Terminal 30: 12.1 V
                        Terminal 15: On
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5Q0-905-861.clb
       Part No SW: 5Q0 905 861     HW: 5Q0 905 861
       Component: ELV-MQBA      H06 0010
       Revision: 00000000    Serial number: 13000019468004
       Coding: 4900000000000000
       ASAM Dataset: EV_ELVMarquMQB 003008
       ROD: EV_ELVMarquMQB_003.rod
       VCID: 73EFC520DA4FD2DE9C-8026
    Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 25021301100469
       Coding: 003B1220D001048000001000
       ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
       VCID: 3F875910A68746BEA8-806A
       Drivers Door Rear Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  007 0002
       Serial number: 00000000000000868765
       Coding: 0D0000
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
       Component: EPS_MQB_ZFLS  119 1021
       Coding: 81
       ASAM Dataset: EV_SteerAssisMQB 008022
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D7B2318AC8B54AEBA-8068
    Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 20021303110868
       Coding: 003B1020DE01048000801000
       ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
       VCID: 3E792414A18D4FB6A3-806A
       Passengers Rear Door Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  007 0002
       Serial number: 00000000000000862897
       Coding: 050000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 858     HW: 5G0 035 858
       Component: MU-S-ND-ER    039 0170
       Serial number: V5F00103130041
       Coding: 02730001FF0000002111120100A800001F0100060100010045
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 69D3A7488883180E26-803C
       Operating And Display Unit 1:
       Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
       Component: ABT_Std_Nav  H44 0020
       Serial number: VWZ8Z9M34018JG
       Data medium:
       Subsystem 2 - Part No SW: 5G0 919 866 D    HW: -----------
       Component:  ECE 2013  --- 0021
       Serial number: --------------------
    2 Faults Found:
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:46:00
                        Voltage terminal 30: 14.3 V
                        BAP-BAP_Function_ID: 02
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:46:00
    End-------------------------(Elapsed Time: 03:57)--------------------------
    I would really appreciate any help on this, many thanks
  2. Re: VW Golf MK7 stop start not working - VCDS report missing ABS controller missing messages
    1837 Post(s)
    Did all these faults clear and then return? Something odd happened at the front of this car around 10.45 on the 28th of December, has it been hit? There are a number of fault codes there which will stop the SSA system working and you will need to deal with them. There are a number of problems here that may be beyond what you can do with VCDS and I can see the need for some work in Guided Fault Finding using ODIS and then having the distance sensor realigned at a VW dealership or one of the few but growing number of alignment centres that can do this. Did you jump start this car or another on the 28th?
  1. Replies: 1
    Last Post: 16-03-2020, 10:14 PM
  2. Missing messages
    By A6S in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 24-08-2017, 09:44 AM
  3. Replies: 0
    Last Post: 25-06-2014, 01:27 PM
  4. Please Help RNS-E code missing on card, how to locate with VCDS
    By monz87 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-05-2013, 02:34 PM
  5. Missing VCDS label files
    By mickmcvw in forum VCDS - General Questions
    Last Post: 22-01-2010, 01:47 PM
