Thread: VW Golf MK7 Stop/Start not working VCDS report ABS controller missing messages?
  1. VW Golf MK7 Stop/Start not working VCDS report ABS controller missing messages?
    Aug 2016
    Out of the blue at the end of 2017 my stop start stopped working. I initially thought the stop start wasn't working as a result of low tyre pressure. However, the problem has persisted. Could anyone please advice on how to fix this issue?
    Code:
    Sunday,14,January,2018,11:47:48:64250
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
    VCDS Version: 17.8.1.0 (x64)
    Data version: 20171130 DS276.6
    www.Ross-Tech.com
    VIN: xxx License Plate: yyy
    Mileage: 149828km-93098mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
    VIN: xxx Mileage: 149828km-93098miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    15-Airbags -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H83 4943
       Revision: 00H83H22
       Coding: 011D0012036505083000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
       ROD: EV_ECM20TDI01104L906021DT_002.rod
       VCID: 7AF1E804FD25A396DF-802E
    3 Faults Found:
    5290 - Throttle Actuator Control Circuit
              P2100 00 [104] - Open Circuit
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 6
                        Mileage: 148256 km
                        Date: 2017.12.15
                        Time: 08:49:38
                        Engine speed: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 15 °C
                        Intake air temperature: 10 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 12.680 V
                        Unlearning counter according OBD: 40
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 100.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.02 %
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 0: 0
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 16: 9
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 24: 55
                        Throttle valve adapter 1 bank 1: monitoring - status-Bit 8: 2
                        Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4506.2 mV
    20558 - Heater Support Pump
              P16C6 00 [032] - Running Dry
              Intermittent - Not Confirmed - Tested Since Memory Clear
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [047] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:55
                        Engine speed: 871.50 /min
                        Normed load value: 22.7 %
                        Coolant temperature: 80 °C
                        Intake air temperature: 66 °C
                        Ambient air pressure: 990 mbar
                        Voltage terminal 30: 12.100 V
                        Limitation: accelerator pedal: 0.0 Nm
                        CAN status - engine control module-Bit 0: 0
                        Cruise Control System (CCS): status-Bit 0: 1
                        CAN status - transmission control module-Bit 0: 0
                        CAN status - brake control module 1-Bit 0: 0
                        CAN status - brake control module 2-Bit 0: 0
                        selected gear-Bit 0: 0
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
       Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
       Component: DQ250-6F MQB  H52 3613
       Revision: 05652103    Serial number: TFK01302020099
       Coding: 0014
       ASAM Dataset: EV_TCMDQ250021 001001
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 152BDBB8F47B6CEE52-8040
    1 Fault Found:
    10763 - Starter Enable from Selector Lever Sensor System
              P1734 00 [002] - -
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
       Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
       Component: ESC           H75 0537
       Revision: 00000000    Serial number:
       Coding: 01FA8AA120210A6F037D060301C92980510450C0608094F3F86A5028C1
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7EF9E414E10D8FB6E3-802A
    3 Faults Found:
    8192 - Databus
              U1121 00 [137] - Missing Message
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:55
    8196 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:55
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 71
                        Reset counter: 191
                        Mileage: 149134 km
                        Date: 2017.12.30
                        Time: 11:07:06
    Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
       Part No SW: 5Q0 959 435     HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0500
       Revision: 00021000    Serial number: 0206610423
       Coding: 030C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002011
       ROD: EV_KessyHellaMQBAB_002_VW37.rod
       VCID: 79F3F708F823A88ED6-802C
    No fault code found.
    Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
       Part No SW: 5G0 907 426 K    HW: 5G0 907 426 K
       Component: AC Manuell    H01 0503
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_002_VW37.rod
       VCID: 336F05209ACF92DE5C-8066
       Fresh Air Blower Front:
       Refrigerant Pressure And Temperature Sender:
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011306001655
       Coding: 03011846C241027B0FA44080B11C0728180A000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 010001
       ROD: EV_BCMBOSCH_010.rod
       VCID: 46894CF4F95D1776EB-8012
       Control Unit For Wiper Motor:
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    130217  042 0551
       Serial number:         130222072350
       Coding: 0E4DD5
       Rain Light Recognition Sensor:
       Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
       Component: RLS  024 0042
       Serial number: Y13M02D22H07M39S40S1
       Coding: 00A8DD
       Sensor For Anti Theft Alarm System:
       Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY130382NFG
       Alarm horn:
       Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Component: Sirene, DWA  004 0311
       Serial number: 00000000000056047921
    3 Faults Found:
    204546 - Remote key 2
              B147A 18 [009] - Current Too Low
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 2
                        Reset counter: 133
                        Mileage: 148128 km
    539925 - Databus
              U1121 00 [008] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 157
                        Mileage: 149005 km
                        Date: 2017.12.26
                        Time: 18:20:02
    934149 - Rain/light recognition sensor
              B1366 76 [008] - Wrong mounting position
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 175
                        Mileage: 149395 km
                        Date: 2018.01.05
                        Time: 10:03:38
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  002 0026
       Revision: --------    Serial number: 94231305500207
       Coding: 0071051011
       ASAM Dataset: EV_EPHVA18AU3700000 002016
       ROD: EV_EPHVA18AU3700000_002_VW37.rod
       VCID: 3A712804BDA563969F-806E
    Address 13: Auto Dist. Reg
    Cannot be reached
    Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Component: AirbagVW20    011 0361
       Serial number: 003M1R01YHGZ
       Coding: 98CCC000000000005C0000CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X_VW37.rod
       VCID: 4A9178C4ED45F3160F-801E
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169677A01031340101
       Coding: 333135
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676A01031370178
       Coding: 333135
       Side Sensor Driver Front:
       Subsystem 3 - Part No SW: -----------    HW: 480 002 202 13
       Component: SideSensor_Df  001 0887
       Serial number: 3576700000059B28DC02
       Coding: 2D2D2D
       Side Sensor Passenger Front:
       Subsystem 4 - Part No SW: -----------    HW: 480 002 202 13
       Component: SideSensor_Pf  001 0887
       Serial number: 3586700000075B113C0Q
       Coding: 2D2D2D
       Side Sensor Driver Rear:
       Subsystem 5 - Part No SW: -----------    HW: 480 402 502 13
       Component: SideSensor_Dr  001 6149
       Serial number: 3516502AD0F8ABF2510Q
       Coding: 2D2D2D
       Side Sensor Passenger Rear:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 502 13
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502A90F8ABF4C27/
       Coding: 2D2D2D
       Front Sensor Driver:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 602 13
       Component: FrontSensor_D  001 6149
       Serial number: 3556502BF0F7B8E39291
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
       Component: Lenks. Modul  007 0070
       Revision: --------    Serial number: 25021308490526
       Coding: 0C00
       Shop #: WSC 40195 333 37120
       ASAM Dataset: EV_SMLSKLOMQB 009001
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 020190E495F5EB5687-8056
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
       Part No SW: 5G0 920 960 A    HW: 5G0 920 960 A
       Component: KOMBI         236 0555
       Coding: 27A401182780260001886A01040000
       ASAM Dataset: EV_DashBoardVDDMQBAB 008026
       ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
       VCID: 2757E1705E17EE7EF0-8072
    3 Faults Found:
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:46:00
    16776960 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:54
    16776961 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:54
    Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000384787
       Coding: 030100040B087300EF00045C1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 346D063C9FC195E645-8060
       Alternator:
       Multi Function Steering Wheel Control Module:
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H12 0034
       Serial number: 02120004537170090291
       Coding: 2D0000
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Component: J367-BDMHella  H03 8042
       Serial number: 8020799101
    1 Fault Found:
    66054 - Extended CAN Bus (SAE Bus C)
              U0047 00 [009] - Performance
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:45:58
                        Supply voltage: Terminal 30: 12.1 V
                        Terminal 15: On
    Address 2B: Steer. Col. Lock (J764)       Labels:| 5Q0-905-861.clb
       Part No SW: 5Q0 905 861     HW: 5Q0 905 861
       Component: ELV-MQBA      H06 0010
       Revision: 00000000    Serial number: 13000019468004
       Coding: 4900000000000000
       ASAM Dataset: EV_ELVMarquMQB 003008
       ROD: EV_ELVMarquMQB_003.rod
       VCID: 73EFC520DA4FD2DE9C-8026
    Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 25021301100469
       Coding: 003B1220D001048000001000
       ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
       VCID: 3F875910A68746BEA8-806A
       Drivers Door Rear Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  007 0002
       Serial number: 00000000000000868765
       Coding: 0D0000
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
       Component: EPS_MQB_ZFLS  119 1021
       Coding: 81
       ASAM Dataset: EV_SteerAssisMQB 008022
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D7B2318AC8B54AEBA-8068
    Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 20021303110868
       Coding: 003B1020DE01048000801000
       ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
       VCID: 3E792414A18D4FB6A3-806A
       Passengers Rear Door Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  007 0002
       Serial number: 00000000000000862897
       Coding: 050000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 858     HW: 5G0 035 858
       Component: MU-S-ND-ER    039 0170
       Serial number: V5F00103130041
       Coding: 02730001FF0000002111120100A800001F0100060100010045
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 69D3A7488883180E26-803C
       Operating And Display Unit 1:
       Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
       Component: ABT_Std_Nav  H44 0020
       Serial number: VWZ8Z9M34018JG
       Data medium:
       Subsystem 2 - Part No SW: 5G0 919 866 D    HW: -----------
       Component:  ECE 2013  --- 0021
       Serial number: --------------------
    2 Faults Found:
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:46:00
                        Voltage terminal 30: 14.3 V
                        BAP-BAP_Function_ID: 02
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 119
                        Mileage: 149058 km
                        Date: 2017.12.28
                        Time: 10:46:00
    End-------------------------(Elapsed Time: 03:57)--------------------------
    I would really appreciate any help on this, many thanks
  2. Re: VW Golf MK7 Stop/Start not working VCDS report ABS controller missing messages?
    Sep 2008
    Highlands
    12 Post(s)
    Hi ,
    did you get this fixed?
    i have similar issue at the moment.
    vince
  1. Disable start / stop via VCDS
    By MC09PJC in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-12-2018, 01:50 PM
  2. Question Touran stop start VCDS coding
    By Alex jb in forum Touran - Sharan - Caravelle
    Last Post: 30-01-2018, 09:16 PM
  3. Stop/Start vcds question
    By Dieseldoos in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-09-2016, 06:38 PM
  4. Replies: 0
    Last Post: 25-06-2014, 01:27 PM
  5. VCDS seatbelt and start/stop
    By wellpist in forum VCDS - Help Requests
    Last Post: 29-06-2013, 10:15 PM
