Thread: New owner - new question re drivers door window switch
  1. New owner - new question re drivers door window switch
    Nov 2006
    Took a gamble last weekend and bought a 2002 1.9 TDI Avant via E Bay, seems OK but has a few things need doing, drivers door window switch is bust, all the google and youtube images I can find show a different design of door card with 4 switches (my car has manual windows in the rear), grateful for advice re whether the switch bezel comes out or do I need to take the door card off (how?) and access from inside? cheers (see pic)
  2. Re: New owner - new question re drivers door window switch
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by pbeardmore View Post
    Door card off.
    While your there check for broken wires in the loom between door and A pillar.
    A4 2.5 tdi QS (mapped)
  3. Re: New owner - new question re drivers door window switch
    Nov 2006
    thanks for the reply, so screws are behind wood effect trim?, every online instruction I can find shows the removal of two phillips screws and then lifting the door car up and out but I dont have the screws on my doors!!
  4. Re: New owner - new question re drivers door window switch
    20 Post(s)
    thanks for the reply, so screws are behind wood effect trim?, some vids show screws at each end plate of door but nothing on mine
    Not sure on screw location.
  5. Re: New owner - new question re drivers door window switch
    Nov 2011
    Duns Scotland
    11 Post(s)
    ON MY 2002 ALLROAD, the door switch is released by pushing a screwdriver up into the hole on the underside of the door handle (the manual recommends this removal is done first before removing the inside door card - but not essential if you are carefull when pulling up the door card for removal). The two philips screws holding the door card on are at either side of the door, just below the window rubber. The door has to be fully open to see the screw at the hinge side. You SHOULD be able to see the one at the lockside - both are at the SIDES rather than on the inside face of the door card. Caviat - ASSUMING YOUR CAR IS LIKE MY ALLROAD.
  6. Re: New owner - new question re drivers door window switch
    Nov 2006
    Thanks for the reply, seen videos on Youtube re your design of door by mines different sadly
  7. Re: New owner - new question re drivers door window switch
    Jul 2015
    Staffs
    46 Post(s)
    The a4 b6/b7 one is very easy to remove. Yours can't be that different.
    Screws under the wooden trim, one at the bottom of the door card, and one behind the door grab handle (under a little cover)
    Ian
    A4 B6 Avant Nogaro Blue
  1. Drivers window switch
    By 5m4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-10-2013, 12:34 PM
  2. Drivers Window Switch
    By richball65 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-08-2013, 08:21 PM
  3. A4 B7 avant drivers door window lost switch function
    By labrador in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-04-2012, 06:37 PM
  4. Drivers Window Switch?
    By Daniel97 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2011, 10:00 AM
  5. Replacing Drivers door arm rest trim and window switch
    By arcing in forum Audi A4 - Archive Topics
    Last Post: 23-08-2007, 12:56 PM
