Thread: 2016 Audi A3 1.6 Tdi rear brake pad change
Results 1 to 10 of 10
  1. 2016 Audi A3 1.6 Tdi rear brake pad change
    Aug 2015
    Hi Guys
    Typically what sort of miles can you get out of the pads before the rear pads need replacing ? My front pads have a wear sensor but NO wear sear on the rear pads. Not sure when to change them.
    Is it a relatively easy job to do ?
    Thanks.
  2. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Jul 2007
    glasgow
    35 Post(s)
    change at same time as front
    have you got an electronic handbrake ?
  3. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Aug 2015
    Quote Originally Posted by niall campbell View Post
    yes
    thanks for your reply. Typically what sort of miles can you get out of the rear pads before they need changing ? is there a 'how to guide' in replacing the rear pads. thanks.
  4. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Jul 2007
    glasgow
    35 Post(s)
    I get 45,000 out of my A6 but that's all dependent on driving style, I tow a 1,800 kg braked horsebox but I am not heavy on brakes
    Front & rear usually last the same time
    You need an Autel VAG505 handheld computer or VCDS to rewind the electronic brakes, to get the caliper off the discs, then a VW three pronged tool to wind in brake caliper. Stick it all back together & tell the computer to wind brakes back on
    Laser 5538 Piston Wind Back Adaptor 3 Pin: Amazon.co.uk: Car & Motorbike you need this to go on the wind back tool . You may need to file off paint on wind back tool to put adaptor on
  5. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    1834 Post(s)
    They are ATE electric calipers and you push the pistons back conventionally, not with a wind back tool.
  6. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Aug 2015
    Many thanks. Oh dear, i've just bought a rewind back tool kit. Does anyone know where i can get hold of a cheap push back brake piston tool that would be suitable for my car ? Thanks.
  7. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    loads of places - local motor factors, halfords, ebay, ECP etc.
  8. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Aug 2015
    brake push back reset tool 1.jpgthank you. would this work ?
  9. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    1834 Post(s)
    Yes, looks spot on. I have an ATE version I have had for years.
    1 1 0
  10. Re: 2016 Audi A3 1.6 Tdi rear brake pad change
    Aug 2015
    Many thanks
  1. Audi A6 C6 2.0TDIE Avant Rear Brake change
    By king air in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-03-2017, 05:14 PM
  2. Question Rear brake discs and pad change Q?
    By go-for-it1 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2013, 11:25 PM
  3. Rear Brake Change
    By IANTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 27-11-2007, 01:07 PM
  4. Rear Brake pad change.
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2007, 03:24 PM
  5. golf IV - rear brake change
    By ned in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-10-2006, 10:13 PM
