Thread: Brake ware Sensor
  1. Brake ware Sensor
    May 2013
    Hello, my break wear sensor light is one, I have asked the local garage they want almost £250 to fix this by putting a new bit of cable in, the problem is on the plug on the engine loom side not the break pad side,
    Does anyone know where I can get just the plug? Or do they only supply it with a loom kit?
    I’m an electrician and generally handy round cars etc so confident I can fix it, but need to get hold of the part,
    Many thanks
  2. Re: Brake ware Sensor
    Jul 2015
    Staffs
    46 Post(s)
    If you can live without the warning sensor joining the 2 wires will probably trick the system into thinking everything is ok. You just have to manually check the pad thickness on a regular basis for safety reasons.
    Ian
    A4 B6 Avant Nogaro Blue
  1. 2.5 TDI Camshaft ware
    By quattrogary in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-03-2011, 09:26 PM
  2. Please Help b5.5 tyre ware
    By jonathan bees in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2010, 01:57 PM
  3. VAG COM & soft ware...
    By scootermap in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-02-2010, 06:15 PM
  4. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
  5. Brake sensor
    By strachan10 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-01-2008, 11:29 AM
