This fault started recently when it got cold. Still starts on the button, hot or cold, but shows with a lumpy motor at idle when cold with corresponding 'actual' fuel pressure jumping all over the place between 80 and 800 BAR(800000 hPa) when the specified is a fairly solid 320 BAR. When warm the lumpy has gone and the fuel pressure actual against specified is correct.
So to determine is the CR fuel pressure sensor playing up when cold and warmed up it is working ok? Has anyone seen this before? Or are there other blocks that might show up any pump/control issue? It's hard to believe the high value could be possible in the rail at idle I would have thought? Seems to be stacks more measuring blocks that might prove something if someone knows here? I have a golf with a similar CR engine which is useful for comparison measurements.
The only other thing I noticed and likely completely unrelated was that the exh gas temp sensor 2 is broken, reading 0 degrees C and no mV output. But no dtc issued for this ? Obviously I'll get onto that soon also.
Address 01: Engine Labels: 03L-906-018-CGL.clb
Control Module Part Number: 03L 906 018 ML HW: 03L 906 018 DN
Component and/or Version: R4 2,0L EDC H22 0794
Software Coding: 2A194012042703080000
Work Shop Code: WSC 00565 210 80803
ASAM Dataset: EV_ECM20TDI01103L906018ML 003003 (AU48)
ROD: EV_ECM20TDI01103L906018DG.rod
VCID: 00047BDD9B9D1D4418-8054
1 Fault Found:
5175 - Fuel Pressure Regulation
P1065 00 [039] - Regulation Discrepancy
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 219683 km
Date: 2018.03.04
Time: 09:15:04
Engine speed: 1294.50 /min
Normed load value: 80.4 %
Vehicle speed: 0 km/h
Coolant temperature: 32 °C
Intake air temperature: 7 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 14.480 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
