Thread: Thermostat coolant level?
  1. Thermostat coolant level?
    Apr 2009
    Hi...when ever the car (a4 2.0tdi b8.5) reaches temp and then I turn on the heaters the temp drops to to 70 degrees or below.from the read ups here on the forum everything points to the thermostat..my question is my coolant level drops to just above minimum. Would this be a normal issue with thermostat playing up?
  2. Re: Thermostat coolant level?
    Jul 2007
    glasgow
    35 Post(s)
    I would replace the cap on the expansion tank for the radiator firstly
    It sounds like the cap is opening to allow steam out before it should, allowing the pressure to drop in the cooling system .............................. it is a pressurised system after all
    Resulting in coolant loss, without a leak !!
  3. Re: Thermostat coolant level?
    Jul 2007
    glasgow
    35 Post(s)
    get a genuine one for around £10 to £15 from Audi
    it sounds as if its stuck open & everyone forgets about the importance of them
  4. Re: Thermostat coolant level?
    Apr 2009
    Thanks for the reply niall...wouldnt have thought the cap could open seems secure enough and no steam leak from it
  5. Re: Thermostat coolant level?
    Jul 2007
    glasgow
    35 Post(s)
    thats because it operates under pressure
    if the cap is stuck open .................................................. you wont be able to tell
    its not like the old radiator cap & worked with a big spring, you could tell if they were stuck open or closed................................... a bit like a thermostat
    As the engine heats the water, steam is formed, just like a kettle or boiling your tatties. If the steam escapes, then when the water cools down, then there is less water
    Except, the expansion cap is designed not to let the steam escape in normal conditions, controlled by pressure; either in pounds or psi
    So if the cap is letting steam escape , you will not see it unless you roast the car, then when the car is cold; the steam does not turn back to water as it has escaped and hence your water level is at the Minimum mark
    At this stage, it is highly likely that
    1) You have a leak
    2) Expansion Cap is not working correctly & cheapest option at £15
    3) Water Pump is not pumping water
  6. Re: Thermostat coolant level?
    Apr 2009
    Thanks that makes alot of sense ..will be replacing the expansion cap
  1. Question Coolant level message but coolant is ok
    By Akash in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-07-2017, 12:08 AM
  2. coolant level
    By fender in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2009, 03:38 PM
  3. Coolant Level!!
    By VW_GTTDI in forum Golf MK5 - 2004 - 2009
    Last Post: 03-12-2008, 10:36 PM
  4. A4 1.8T low coolant level
    By kit in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-05-2008, 09:40 PM
  5. Coolant level
    By djsoftware in forum Passat - Archive Topics
    Last Post: 08-08-2006, 01:13 PM
