Thread: Passat B6
  1. Passat B6
    Feb 2018
    Norwich
    Hi guys
    Have a 2006 2.0tdi DSG B6 Passat
    150,000 miles
    Couple of issues I need help with
    1) the heater only blows warm air when on hottest setting I have noticed when the heating is on in the car the engine temp gauge on the dash doesn’t move If I change the air temp in the car to aircon the temp engine gauge goes to half way.
    2) driving today I had the following lights come on
    ABS
    TRACTION CONTROL
    HANDBREAK FAULT
    Please can anyone offer me any guidance on these issues
  2. Re: Passat B6
    Jan 2015
    Nottingham
    Hello pal
    Try and get the car scanned and post the results here .
    That will give more information and point you in the right direction.
  3. Re: Passat B6
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Regarding the 1st issue, I would say the thermostat is stuck open.
    As you have a DSG it will have 2 thermostats, 1 for the engine which rarely fails, & 1 for the DSG which seems to be a common failure & luckily is the easiest to change.
    Issue 2 could be a duff ABS sensor, but you need a scan to get the codes.
  4. Re: Passat B6
    May 2012
    Everywhere
    308 Post(s)
    Also fix this .
  1. Question Vw passat b6 passat 2.0 tdi sport cam shaft sensor replacement
    By MUNK19 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-04-2017, 10:24 PM
  2. Dirty Passat.. Nice Day.. Bored at Work = SUPER SHINY PASSAT!!
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2010, 12:10 PM
  3. Replies: 0
    Last Post: 09-04-2010, 03:07 PM
  4. Question Boot mounted CD changer from 1997 Passat to 2003 Passat
    By philnewman2002 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-12-2008, 02:52 PM
  5. Passat Sport to Passat 4Motion - Good Move?
    By Baron_Samedi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-07-2008, 09:44 AM
