Thread: Running issues
Results 1 to 10 of 11
  1. Running issues
    May 2015
    Somerset
    Hi all got a 2.0 TDI 06 Passat, has no eml light on, just limiting itself to 3.5k revs, I've unplugged the maf sensor but no change! If I accelerate slowly it's ok but put my foot down and it's lumpy with no power.. Could anyone please help shed some light on the issue. Many thanks.
    Sent from my CUBOT MAX using Tapatalk
  2. Re: Running issues
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by mcleemo View Post
    Lots of things make a 2.0 PD lumpy. What's your mileage and engine code? Engine code should be on white printed sticker in boot wheel well under carpet. Also there may be fault codes that are recorded but which do not throw up a dash warning. A fault code scan with a VW capable scan tool (VCDS, VAS or higher functioning scan tool) would be advisable. There are engine parts that cause 'limp mode' some of which will not register a warning light until more serious.
  3. Re: Running issues
    May 2015
    Somerset
    Thanks for the reply bud, sorry it's a bkp I think, 113000 miles, I have vcds will plug it in when I have a chance. I used torque Pro app first off but nothing came up.
    Think I need to work the actuator free, could I do this on the car? Thanks.
  4. Re: Running issues
    Jan 2012
    10 Post(s)
    87 Post(s)
    When you say work the actuator free? Is it rigid with no movement? A fair few VNT turbos get clogged up with carbon and soot preventing the vane actuator ring from rotating but this normally throws up under / over boost fault codes, limp mode and often the dash fault light. Has it already had its first timing belt change (due at 95k on this year of PD)? Also a deteriorating Dual Mass Flywheel can separate and the front plate jam causing vibration and poor power. Almost feels like a cylinder isn't firing, pickup from stationary would be awful and possibly with an engine 'shudder' when accelerating. Clutch bite could get much further down as it gets worse.
  5. Re: Running issues
    May 2015
    Somerset
    Quote Originally Posted by DMitch16 View Post
    A little stiff on movement but now you've told me about the eml light I'm thinking it's something else. I plugged my vcds and I have one code
    • intermittent implausible signal Injector 4.
    So I'm looking for a new Injector and fit it right?? Cheers bud, awesome reply, thank you.
  6. Re: Running issues
    Jan 2012
    10 Post(s)
    87 Post(s)
    More likely to be the loom than the injector although the injector itself can't be ruled out at this stage.
    New loom is around £120 but used ones are around for less.
    The test is to swap injectors 3 and 4 and see if the injector 4 fault moves with it to injector 3. If it stays at 4 it's the loom not the injector.
  7. Re: Running issues
    May 2015
    Somerset
    More likely to be the loom than the injector itself although the injector itself can't be ruled out at this stage.
    Just your help may have saved me £££, thank you. Well that sounds less stressful (I hope) Is the loom a DIY job?
  8. Re: Running issues
    Jan 2012
    10 Post(s)
    87 Post(s)
    Depends on your mechanical proficiency. It's a medium difficulty job but does not need any special tools as such as long as you have a reasonable tool kit. A loom change is recommended when you change injectors anyway as the old one would be more brittle and subject to possible damage upon removal. A few tricky bits such as not losing the red loom collar plastic locking pin, being careful not to break the injector or glow plug connectors or drop anything into the head. Also the connector 'collar' is in 2 parts outer and inner collars. The inner one has a retaining clip on the inside part of the head which needs to be removed and the collar may be very, very stiff. I use a rope or strap to undo it (coiled around once, pulled tight and then using a push-me-pull-me type motion with each end to undo the collar) but do not feed it through as the loom rail needs to be unbolted first iirc 3 hex head bolts, with female hex heads. Then remove the loom from out of the head mounting hole.
  9. Re: Running issues
    1840 Post(s)
    When you read the fault codes with VCDS you will have no idea if your Air Mass Meter is faulty as you ran the engine with it unplugged before checking the codes.
  10. Re: Running issues
    May 2015
    Somerset
    Hey pal, I ran it when off and on, made no difference. I remember while idling it was reading between 240-270. The injectors were
    0
    0
    -29
    0
  1. Polo 1.2 running issues
    By mike ryan in forum Polo - Derby - Lupo - Fox
    Last Post: 10-02-2014, 04:14 PM
  2. Please Help 1999 A4 2.5 tdi running issues
    By Craigyb1980 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-06-2013, 01:19 PM
  3. Question A4 running issues
    By Andy123L in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-01-2012, 07:33 PM
  4. hi everyone (running issues)
    By muskey01 in forum New Member Introductions
    Last Post: 22-04-2008, 08:53 PM
  5. 83 polo running issues
    By Dave83polo in forum Polo - Derby - Lupo - Fox
    Last Post: 08-03-2008, 03:49 PM
