Thread: Faulty A6 CD Changer
Results 1 to 10 of 11
  1. Faulty A6 CD Changer
    11 Post(s)
    As some of you may know from my previous thread, Iíve been having problems with something draining the battery on my 2005 A6. The garage think it is the CD changer which is faulty. I donít know how the electrics in the vehicle work, but if I remove/replace the changer, should that solve it, or is the power component of it separate?
    Next question is anyone selling a 2G AMI unit? Seems pointless replacing with another CD changer, I may as well try and find a second hand AMI unit.
  2. Re: Faulty A6 CD Changer
    Jul 2013
    50 Post(s)
    You would need a most loop bridge to get the MMI back up and running.
    They can got got on eBay.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Faulty A6 CD Changer
    11 Post(s)
    Iíve seen a few threads on VNSmedia. Does anyone know if I could remove my faulty CD changer and just put a VNSmedia unit in instead? Would everything still work without the Changer in line?
  4. Re: Faulty A6 CD Changer
    Oct 2012
    Estonia
    60 Post(s)
    Quote Originally Posted by prophet View Post
    I’ve seen a few threads on VNSmedia. Does anyone know if I could remove my faulty CD changer and just put a VNSmedia unit in instead? Would everything still work without the Changer in line?
    Yes, it should work, but check with vns just in case(there is no spec info on website), if memory correct, it was 2g low "thing" that you needed to keep cd, but could be wrong. Oem works with and without!
    IF THIS YOU AFTER:
    Audi Music Interface MMI 2G All in One Bluetooth Streaming NAVISERVICE VNSmedia
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  5. Re: Faulty A6 CD Changer
    11 Post(s)
    Yes thatís the unit Iím after. I guess really I need to remove the CD changer first and then put in a MOST loop bridge as Dan suggested. See if that cures the battery drain issue, then add the VNS Media after that.
  6. Re: Faulty A6 CD Changer
    Oct 2012
    Estonia
    60 Post(s)
    Yes that’s the unit I’m after. I guess really I need to remove the CD changer first and then put in a MOST loop bridge as Dan suggested. See if that cures the battery drain issue, then add the VNS Media after that.
    Yep, thats good plan, without loop you can do trick with tape or with tube...but proper loop is best and may become handy in future also!
  7. Re: Faulty A6 CD Changer
    Dec 2008
    Stoke-on-Trent
    I have an AMI unit coming up for sale within the next week. I purchased it brand new and would come with power and fibre cables.
    Apple lightening lead and USB as well.
    would be looking for £250 delivered
    This could replace the CD multiplayer or in my case I fitted it alongside.
    will also have a full genuine 2G dab kit available as well with everything from the unit, bracket amplifier and cables. basically everything you need apart from an antenna. mine being an Avant, I just used the one built into the rear quarter.
    Haven't thought about prices yet, just need to get these removed from the car before I sell it
    Simon
    2007 Avant 3.0 tdi Le Mans
  8. Re: Faulty A6 CD Changer
    11 Post(s)
    Quote Originally Posted by stokey1964 View Post
    Simon
    Thanks Simon, I will bear that in mind. I have to admit that Iím tempted to order the VNS Media unit. Integrates into the MMI without any coding and has the added benefit of built in Bluetooth streaming as well. Itís around £200
  9. Re: Faulty A6 CD Changer
    May 2016
    London
    18 Post(s)
    When swapping cd changer you need to remove component protection
    Sent from my SM-G950F using Tapatalk
  10. Re: Faulty A6 CD Changer
    11 Post(s)
    Quote Originally Posted by niedzial1983 View Post
    Ooh. How do I do that? Iím awaiting delivery of the VNS Media box, and when I spoke to them, they said simply unplug the CD Changer and plug into their box.
    55plate Audi A6 Avant. 3.0Tdi S-Line Quattro.
  1. Faulty cd changer
    By Fanatic in forum In Car Entertainment
    Last Post: 28-12-2014, 11:24 PM
  2. How To Audi concert Aux in through CD changer, but canít select Changer on head why?
    By eddie_baby in forum In Car Entertainment
    Last Post: 13-06-2012, 05:47 PM
  3. 6cd changer into 1 cd changer mmi basic straight swop?
    By Quattros in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-09-2011, 12:08 PM
  4. Replies: 0
    Last Post: 11-06-2011, 12:23 PM
  5. Faulty CD Changer??.....
    By oDUTCHYo in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-09-2009, 10:16 PM
