Thread: vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
  1. vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
    Feb 2018
    sheerness
    hi ,the temperature on my golf stays low,had a new thermostat fitted,but takes an age to get any heat out of blowers and never gets to 90 degrees gone into the temp control sender in case but havent fitted yet any ideas??? cheers for any help
  2. Re: vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
    Aberdeen
    63 Post(s)
    Welcome to the forum. I have moved your thread to the correct section.
  3. Re: vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
    May 2018
    Midlands UK
    Hi mate, having the same issue on mine - I thought it was the thermostat but haven't got round to it yet. My oil temp temp reaches 60-70c before my water temp needle even moves. Mine also really struggled to start over winter when the ambient temperature was low. It would crank over for ages then have a lumpy idle for a second or two. This was only ever experienced on the first cold start of they day.
    I'm also experiencing a hiss from the turbo under partial load which I cant get to the bottom of!
    (2012 GOLF MK6 DSG CFFB)
  4. Re: vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
    Jan 2018
    Sussex
    55 Post(s)
    If its DSG there is another thermostat, that could lead to heat loss.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  5. Re: vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
    Aug 2019
    Telford Shropshire
    9 Post(s)
    Quote Originally Posted by Renars View Post
    That's true there is temperature sensor/for the coolant
  6. Re: vw golf 2011 gttdi 140 ,temperature stays very low rarely gets to 90o
    1841 Post(s)
    As it was well over a year ago you would hope it I sorted.....
  1. Question I rarely lock my car. Anyone else?
    By Naeyin in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-02-2016, 08:44 AM
  2. golf mk3 foglight stays on
    By yas_b in forum Golf MK3 - 1993 - 1999
    Last Post: 17-11-2009, 04:29 PM
  3. Golf MK5 '04 GTTDI 140 Map
    By Vapor in forum Golf MK5 - 2004 - 2009
    Last Post: 20-04-2009, 02:47 PM
  4. temperature sensor on golf gttdi 130
    By denibabe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-03-2009, 10:12 AM
  5. Audi A3 Coolant temperature stays at 60!
    By Shirley in forum Audi A3 - Archive Topics
    Last Post: 23-01-2008, 01:39 PM
