Thread: 1.4 TSI 122 Engine Problems....
Results 1 to 10 of 16
  1. 1.4 TSI 122 Engine Problems....
    Feb 2018
    Right so...
    It does not happen every time but it has happened often enough over the past 2 weeks.
    Whenever the car has been sat for more than 8-12 hours or if it is really cold outside when i go to turn the car on, it will not start as it should the engine will shake and it will sound rough as F!!! The engine light will be on and the rev counter just drops right down.... i have not left it on long enough to see too much as i just turn it off straight away.
    I will turn off the car and try to restart and after a couple of attempts the car will start.. the engine light will be off and the engine sounds and drives as it should.
    Today when putting petrol in i turned the car on and there was a slight vibration/judder nothing major and the engine light flashed on and off. Misfire?
    What could the problem be?
  2. Re: 1.4 TSI 122 Engine Problems....
    Jul 2007
    glasgow
    35 Post(s)
    you need the car scanned
    I use a autel vag505
  3. Re: 1.4 TSI 122 Engine Problems....
    Feb 2018
    What do you think it could be? I will get it scanned when i can.
    Fuel filter has been suggested to me on another forum?
    Coil pack?
    Something more serous?
  4. Re: 1.4 TSI 122 Engine Problems....
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
    The cheap generic scanners give bad results.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  5. Re: 1.4 TSI 122 Engine Problems....
    Feb 2018
    Yeah i am going to take it to somebody to look at on friday but was just posting on here incase.
    I would like to add i have noticed something this morning.
    So first thing after it has been left over night... i go to start the car and it will either not start or start but will sound rough and the rev counter will just drop and it will cut out... now before i would turn the car off and leave it a couple of seconds and go again and it would take me a fair bit of time before it would eventually start.
    Well i have noticed if i start > turn off > then instantly turn the key again to start straight away before it fully turned off it will only take 1 or 2 trys and it will start?
  6. Re: 1.4 TSI 122 Engine Problems....
    1840 Post(s)
    If it has done a lot of miles and only had a couple of services then chain wear is becoming a major issue on the CAXA engine, it makes them sound awful at start up and then they jump and **** a valve.
  7. Re: 1.4 TSI 122 Engine Problems....
    Feb 2018
    Yeah i heard about the timing chain issue, it has 58k Miles and has been serviced regularly. You think there is a chance it could be that? It does sound good after the initial start up problem
  8. Re: 1.4 TSI 122 Engine Problems....
    1840 Post(s)
    It is something which would come up on a code scan as a G40 implausible signal error so a code read first. By regular servicing do you mean according to the interval every 2 years 18K miles?
  9. Re: 1.4 TSI 122 Engine Problems....
    Feb 2018
    Alright getting it scanned tomorrow so will probably find out the good or not so good news .
    Erm.. serviced 10K Miles - 18K Miles - 22K Miles - 35K Miles - 38K Miles - 49K Miles - Now due another at 58K miles
  10. Re: 1.4 TSI 122 Engine Problems....
    1840 Post(s)
    If at the oil chnage it rattles really badly for a few seconds, this is a good warning sign. With the intervals it has been done at I would hope and expect it to not have chain wear.
  1. Please Help VW Fox Engine Problems
    By jdm0301 in forum Polo - Derby - Lupo - Fox
    Last Post: 22-03-2012, 10:47 AM
  2. B8 Engine problems
    By alamel in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-08-2008, 06:48 PM
  3. Please Help 1.8t engine problems
    By novacav in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2008, 12:39 AM
  4. ADY engine problems
    By RedOne in forum Golf MK3 - 1993 - 1999
    Last Post: 31-03-2008, 01:05 PM
  5. A6 2.4 Engine Problems Please Help!
    By davo79 in forum Chat - Anything with wheels
    Last Post: 16-09-2007, 07:09 PM
