Thread: PCV - Positive Crankcase Ventilation
  1. PCV - Positive Crankcase Ventilation
    Mar 2016
    Minervois, France
    53 Post(s)
    I understand that this requires an inlet to the interior of the engine, to provide fresh air to purge the crankcase, and an outlet from the engine interior to the air intake, so that the gases from the crankcase are burned in the cylinders.
    On my car the outlet from the crankcase is through the Breather Assembly on the left side, and is piped to both the inlet manifold via a one-way valve and to the turbo intake hose via the PCV valve, but I am unable to locate an air inlet to the engine interior.
    Can someone please tell me where this is, if it exists?
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
  2. Re: PCV - Positive Crankcase Ventilation
    Mar 2016
    Minervois, France
    53 Post(s)
    Does nobody know if there is an air inlet to the crankcase or valve cover on a 1.8 T, AEB engine?
  3. Re: PCV - Positive Crankcase Ventilation
    1840 Post(s)
    It is taken from the air intake post air mass meter.
  1. Question LTFT at idle is around positive 10% - what can be the issue?
    By crok in forum Golf MK4 - 1999 - 2004
    Last Post: 22-10-2023, 09:13 PM
  2. 12v positive when ignition off, please read.
    By c2lby in forum Golf MK5 - 2004 - 2009
    Last Post: 06-04-2013, 11:02 AM
  3. Looking for a positive 12v wire in the boot.
    By Smartpainter in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-11-2009, 08:36 PM
  4. Crankcase Ventilation
    By cbrpaul in forum Touran - Sharan - Caravelle
    Last Post: 06-08-2009, 10:17 PM
  5. Handbrake Issue with positive result
    By forge197 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2009, 08:43 PM
