Thread: Has anyone had noise issues using Pagid brake pads?
Results 1 to 10 of 10
  1. Has anyone had noise issues using Pagid brake pads?
    May 2008
    21 Post(s)
    Wifes 2011 A6 fitted new Pagid brake pads 2/3 weeks ago, been fine since but now shes reporting grinding noise when cornering at slow speed, ie turning in or out of a junction.
    Rear pads came with the stainless pad slider widgets, everything cleaned up prior to fitting new pads, slider pins removed and greased with proper slider pin grease.
    Quick check when she got home tonight showed them to all be quite warm and slightly smelly, covered 2/300 miles at most.
    I will take them down again and check, just looking for some advice on what else it may be?
  2. Re: Has anyone had noise issues using Pagid brake pads?
    Jul 2013
    39 Post(s)
    When they have worn down to nothing then they can get a noise as to describe.
    Have you got a sticking piston on one of the calipers.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Has anyone had noise issues using Pagid brake pads?
    May 2008
    21 Post(s)
    Dan no they were all lovely and smooth and retracted nicely no sticking etc.
    I asked her how it was today when she got home? oh its fine she said no noise and no smell!
    I can only assume the smell was new pads bedding in and as for the noise gawd knows?
    On the bright side its meant to be cold this weekend and now I havent got to take it apart
    On the downside mates coming around with his range rover v8 diesel with possibel vgt issues!
  4. Re: Has anyone had noise issues using Pagid brake pads?
    12 Post(s)
    249 Post(s)
    If you do not fit new discs all pads can do this as they try and bed in, we have got the the point of refusing to do pads only due to the squeal comeback issue. We use Pagid all day long and have done for 30 years.
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  5. Re: Has anyone had noise issues using Pagid brake pads?
    May 2008
    21 Post(s)
    Thats great thank you, the reason I went for them was the factor offered me a choice and I used to use Pagid brake shoes on hgvs about 20 years ago and they were okay so thought why not?
    I fit pads all day long at work on the trucks and they also smell after their test drive, but very quickly goes away, but thinking abiut it thats because they do a 2/3000kms per week!
    I think it was the nosie that threw me, especially as her descriprion was as usual vague beyong belief
  6. Re: Has anyone had noise issues using Pagid brake pads?
    Nov 2017
    UK - NORTHEAST
    8 Post(s)
    Iíve had pads that have squealed and got hotly just as you described and it was down to the paint thickness on the locating lugs that fit into the stainless shims, they were sticking and not letting the pads move freely, 5 minutes and some sand paper all sorted..
  7. Re: Has anyone had noise issues using Pagid brake pads?
    May 2008
    21 Post(s)
    Quote Originally Posted by Pete_NorthEast View Post
    I’ve had pads that have squealed and got hotly just as you described and it was down to the paint thickness on the locating lugs that fit into the stainless shims, they were sticking and not letting the pads move freely, 5 minutes and some sand paper all sorted..
    We get the same with the trucks due to paint on the end of the pads and rust in the calliper carrier sliders, needle gun soon sorts that out.
  8. Re: Has anyone had noise issues using Pagid brake pads?
    Jul 2011
    Near Uxbridge
    Quote Originally Posted by lynalldiscovery View Post
    Hiya.....are you sure it's the brakes?
    Check the power steering pump...my power steering fluid level was very low and it showed symptoms exactly as your wife describes. Low speed into and out of corners I'd get a grinding noise coming from the front of the car.... New fluid put in and system bled and it's been fine ever since.
    Sent from my SM-G955F using Tapatalk
    2009 Audi A6 Avant 2.0 S-Line TDIe Phantom Black
    2009 Audi A3 Sportback 1.9 TDIe Sport Brilliant Red
  9. Re: Has anyone had noise issues using Pagid brake pads?
    May 2008
    21 Post(s)
    Quote Originally Posted by neilos100 View Post
    No fluid is fine I check them all every week or so, Im a bit **** like that.
  10. Re: Has anyone had noise issues using Pagid brake pads?
    12 Post(s)
    249 Post(s)
    We call it a descaler gun but it is the same thing and what we do as well to the whole caliper and carrier. We have a blasting cabinet and can do them that way but it is unnecessary and takes too long. We also air gun wire wheel the sliders and use Wurth Aluminium paste on the contact faces.
  1. Pads need replacing - would anybody recommend Pagid?
    By toff in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-05-2017, 10:48 AM
  2. Pagid pads/discs - vibration when hot
    By b206 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-05-2015, 07:23 PM
  3. Question Pagid Brake discs warping
    By acebundi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-09-2014, 08:44 PM
  4. pagid brake pads
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-07-2013, 09:31 PM
  5. Please Help Brake pads and disc issues
    By summerslife in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-04-2010, 09:15 PM
