Thread: Egr delete will dpf regen ?
  1. Egr delete will dpf regen ?
    Mar 2015
    Wirral England
    2007 A6 2.0 tdi
    Hi guys, looking for some advice. If i blank off my EGR valve and get it deleted out will my DPF still regenerate. I had Egr blanked off for last few months without getting it mapped out and its just come up with a DPF fault. I had to unblank it to get the dpf to regen and clear the fault. TIA
  2. Re: Egr delete will dpf regen ?
    May 2012
    Everywhere
    308 Post(s)
    The egr is an prerequisite of dpf regeneration , it helps regulate both the pressure and temperature .
  3. Re: Egr delete will dpf regen ?
    Mar 2015
    Wirral England
    Quote Originally Posted by Gazwould View Post
    Ah ok thanks, so basically 2 choices, dont blank off the egr or get the dpf removed and risk mot failure under new laws
  4. Re: Egr delete will dpf regen ?
    May 2012
    Everywhere
    308 Post(s)
    Here's the fun , the default limit for your 07 will be a slack 3.00, egr and dpf Stage 1 no problem .
    However if lower the manufacturers figure will apply and it certainly will be lower , what's yours , bottom right on VIN , probably around 0.5 ?
  5. Re: Egr delete will dpf regen ?
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    These DPF filters surely are a pain in the A**E, drove 15 miles on the motorway then the DPF decided to do a regen when I parked up at work, I drove back out for 5 minutes doing 2500rpm and it still didn’t finish. Ended up turning it off and walking away....
    1 1 0
  6. Re: Egr delete will dpf regen ?
    Mar 2015
    Wirral England
    Cars engines are way too complicated nowadays, they say its for the environment but i say its to make them more money
  1. Dpf regen
    By Stbb748 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 23-05-2018, 05:23 PM
  2. DPF regen
    By fronty in forum Q7 - 4M Forum - 2016 -
    Last Post: 29-12-2017, 02:59 PM
  3. dpf regen
    By dieselal in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 15-02-2016, 10:16 AM
  4. Dpf regen
    By Chuck32 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-03-2014, 08:18 PM
  5. DPF Regen
    By Sportwag in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-01-2012, 06:42 PM
