Thread: Help with Fault codes
  1. Question Help with Fault codes
    Mar 2014
    Nottingham. UK
    I've just had the car scanned by a local garage but the details are abit minimal.
    4699 - Function restriction due to received malfunction value. (Any ideas what exactly this means? Whats at fault?)
    9444117 - Front passenger front airbag sensor. (Where is this located ?).
    00797 - Sunlight photo sensor. (Located on dash) is it easy to replace?
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  2. Re: Help with Fault codes
    Jul 2008
    Lisburn
    15 Post(s)
    There's more to the codes than that. Vag com will give detail ie limits reached or unable to talk to etc.. 2 routes here Vag com about £200 or obd eleven yes eleven down side with later is that it is android only gives full scan info but vag com functions are pay as you go. But it's about £40.
  3. Re: Help with Fault codes
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by swalker View Post
    What about these Ross tech cables? Are they the same thing as vag com?
  4. Re: Help with Fault codes
    Jul 2008
    Lisburn
    15 Post(s)
    Yep vag com vcds rosstech same thing.
  1. 1.8T with fault codes.
    By jwalman in forum Beetle 2000-
    Last Post: 12-07-2010, 01:35 PM
  2. Please Help A3 Fault codes Radio Fault
    By MAFED in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-05-2010, 04:21 PM
  3. Fault codes
    By evokid in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 02-04-2010, 11:31 AM
  4. new fault codes
    By allroadkev in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-11-2008, 12:31 AM
  5. any one had these fault codes??
    By Adamtdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2008, 12:27 AM
