Thread: non runner...
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. non runner...
    Jul 2008
    Lisburn
    15 Post(s)
    The car just cut out while driving normally. I managed to curse it into the next car park. It will crank and try to start but Just won't go. It's as if it is only going on a couple of cylinders. A scan threw up p0328 crank speed senors out of range. changed this with no joy, since found out the rev counter is working so sensor working. And could be fuel related. Got to the pump and it seems to him at the right time. Hoses around the filter feel under pressure ie no real flex. What next? The car is a few miles from house so making a tad hard..
    Thanks for reading all suggestions welcome.
  2. Re: non runner...
    Feb 2016
    manchester,uk
    14 Post(s)
    Did you put original sensor or aftermarket ?.
  3. Re: non runner...
    Jul 2008
    Lisburn
    15 Post(s)
    It was after market but as pointed out on this forum over on the passat section this runs the rev counter and the car could still run on cam sensor.
    Confused....
  4. Re: non runner...
    Jul 2015
    Staffs
    46 Post(s)
    what engine?
    Ian
    A4 B6 Avant Nogaro Blue
  5. Re: non runner...
    Jul 2008
    Lisburn
    15 Post(s)
    oh sorry my signature seems to have disappeared -
    ASB 3.0 diesel V6- log from fault shows intermitten out of range so more happy sensor is good:-
    01 Engine
    System description: 3.0L V6TDI G000SG
    Software number: 4F0910409A
    Software version: 0010
    Hardware number: 4F0907401C
    Coding: 0011312
    Trouble codes:
    P0321 - Ign./Distributor Eng.Speed Inp.Circ. Range/Performance Upper limit exceeded Intermittent
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  6. Re: non runner...
    Feb 2016
    manchester,uk
    14 Post(s)
    You need to put in original sensor.I disagree car can run on cam sensor.
    From experience I had many years ago BMW 318 Ci and it would not start, bought a crank sensor from Euro car part,car started very oddly,week later car would not start,went scrappy yard got one out of the car,came home bang it on and never had problem after that,so if you want the issuing resolving buy original.
  7. Re: non runner...
    Jul 2008
    Lisburn
    15 Post(s)
    Thanks will try that then. Still trawling net for other options seen a post about s q7 where if 1 injector fails the ecu shuts all down and dosent log a fault!?!? They suggested disconnecting 1 injector at a time and trying it should start if this is the case
    Thanks for replying.
    Stewart.
  8. Re: non runner...
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    [QUOTE=f927;1081193]You need to put in original sensor.I disagree car can run on cam sensor.
    He may be referring to the PD engine where it will eventually fire after a prolonged crank if it cannot match cam/ crank initially. I dont know if it works on his engine.
    Alan.
    VW T6 150 DSG Camper £££
  9. Re: non runner...
    Jul 2008
    Lisburn
    15 Post(s)
    ☹ genuine sender fitted still no go...
    The engine will try enough to disengage the starter and will stumble for upto 10 or 15 seconds but then stops.
    Help. Going to have admit defeat and get her towed...
  10. Re: non runner...
    Jul 2008
    Lisburn
    15 Post(s)
    Right went back over and checked voltages at the crank and cam sensor. Just shy of 5 at cam , 5 is correct and getting a voltage at crank. Not reading too much into the low voltage as the battery is pretty flat at this stage seen a low battery warning come up just after taking the cam voltage. Only one cam sensor that i can see on the right hand side bank.
  1. a3 non runner
    By keeta in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-02-2011, 07:12 PM
  2. Value of a non runner
    By Rachel in forum Golf MK4 - 1999 - 2004
    Last Post: 06-11-2009, 07:35 PM
  3. A6 1.8T non runner
    By brianRR in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-12-2008, 02:54 PM
  4. No runner
    By A4quattro2.5td in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-11-2008, 09:24 AM
