Thread: Bora - dreaded door problems
  1. Bora - dreaded door problems
    Feb 2018
    Surrey England
    Hi Forum
    Hoping for some advice. I have 2005 Bora TDI and the dreaded central locking is playing up. Passenger rear door will not open - have tried various permutations. Managed to get door card removed with door in closed position. Pulled the cables, pushed the rods and poked the leavers (through holes) and removed / refitted the fuse. I have “tapped” door inside and out with rubber hammer - no joy (but hammering the troublesome door was therapeutic). Although, after this I could hear some motor movement in the stuck lock. And, oddly after all this attention when I fiddle with the stuck lock it triggers the central locking in the other doors (as if I pressed the remote).
    I am wondering if this development suggests an electrical fault - maybe still in the lock module but at least I have a symptom to diagnose. From what I have seen on line, this isn’t uncommon and wondered if there is anything anyone can advise.
    And I am still stumped on how to get the door open.
    Thanks Bertie
  2. Re: Bora - dreaded door problems
    Feb 2016
    manchester,uk
    14 Post(s)
    The door lock has become faulty.You will need to change the lock to cure the system.
  3. Re: Bora - dreaded door problems
    Feb 2018
    Surrey England
    Thanks for reply f927 - I know this subject has seen a lot of posts so much appreciate you taking the time.
    I am expecting to fit a new lock but I don’t know how to open the door.
    Do you have any suggestions for how I can do this ?
    thanks again B
  4. Re: Bora - dreaded door problems
    May 2012
    Everywhere
    308 Post(s)
    You break through the casing in a certain place and 'walk' using two flat bladed screwdrivers, a white plastic cog wheel .
  5. Re: Bora - dreaded door problems
    Feb 2016
    manchester,uk
    14 Post(s)
    My way of opening the door is, open the front door see how the door bolted on either on the pillar or on the door, undue the bolts,pull the door out and support the weight of the door, stop it from being dropping, take off the door card and that will give you access to the lock.
  6. Re: Bora - dreaded door problems
    Feb 2018
    Surrey England
    Thank you both so much
    I had no idea what a pain in the tailgate this is
    Sounds a poor design that there is no way to spring the lock by hand from inside the door
    B
  7. Re: Bora - dreaded door problems
    Feb 2016
    manchester,uk
    14 Post(s)
    Hello Bertie,as described thats how I opened the door on Polo 54 plate.
  1. Greetings and the dreaded door lock question.
    By MrPassat02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-11-2016, 03:38 PM
  2. The dreaded Door unlock issue!
    By elgaz in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-04-2016, 06:03 PM
  3. Question dreaded rear door lock
    By stephenwhite990 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-02-2015, 12:04 PM
  4. Replies: 4
    Last Post: 01-03-2009, 04:17 PM
  5. New boy with Bora & stuck door problems
    By flick5848 in forum New Member Introductions
    Last Post: 10-12-2008, 12:31 PM
