Thread: Q7 Door coding - help please
  1. Q7 Door coding - help please
    Aug 2007
    Nottingham
    Hi Guys
    I kind of messed up door coding on a friends audi q7
    the story is he wanted to enable fold mirros on lock so I with into door module for drivers door and in 'coding' rather than add the values to original value, i wiped it and replaced with what i thought was correct and saved it without noting the old code.
    he now tells me the door controls work the wrong way round? down is up and up is down, closing door is opening door, n stuff?
    its a 2009 audi q7 - uk model - has folding mirrors. i understand you cannot reset the code so was hoping someone can help me sort this one out? can I grab the passenger door code and put this in drivers door to sort this? i really need help please?
  2. Re: Q7 Door coding - help please
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by nizzex View Post
    Hi Guys
    There are a couple of ways to get the original coding back to where it was:
    1. If you did an Autoscan before you made any changes, this will have the original coding for the door module in it. Take a look in C:\Ross-Tech\Scans and you should find the scan saved there (if you did one).
    2. Failing that, there is a Debug folder in C:\Ross-Tech. This contains the coding from both before and after you made changes, so you can see what the coding was before you did anything. Just put that coding back into the module.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  3. Re: Q7 Door coding - help please
    Aug 2007
    Nottingham
    Quote Originally Posted by MFGF View Post
    Cheers!
    MF.
    This sounds hopeful. I appreciate your response. I will report back tomorrow
  1. Replies: 0
    Last Post: 19-01-2018, 04:45 PM
  2. Do new door locks need coding
    By sti5300 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-10-2014, 11:28 AM
  3. Drivers door fault. Will it need coding?
    By approvedlunatic in forum Golf MK5 - 2004 - 2009
    Last Post: 07-05-2014, 10:37 AM
  4. Replies: 8
    Last Post: 25-02-2013, 09:43 AM
  5. Passenger Door Coding Golf MK5
    By onzarob in forum VCDS - General Questions
    Last Post: 17-03-2009, 02:33 PM
