Hi guys..what you think which worn control arm on the front causing car wobble at very low speed side to side and float at high speed..front axle lower rear or front axle upper rear control arm. Thing is that my car does wobble at low and floats at high speed..I inspected and found that control arms that i mentioned are on its way out but cant replace just now all of them..i must pick..lowers or uppers first. No knocking just wobble and floating..rubber bushings.
