Thread: 2012 A6 3.0 start button failure
  1. 2012 A6 3.0 start button failure
    Feb 2018
    Herts, UK
    Only when its cold..
    I press start button/brake, The RED LEDs round Tacho all light together, then one after the other i get full range of failures, stop/start failure, ESC failure, Tyre Pressure failre, brake failure, gearbox failure, maybe other as well.
    Press Start Button again, shuts everythinbg off and we start again..
    Eventually, the RED LEDs light up one by one, and it starts then its fine no failures no problems.
    I have had a new door fitted, AUDI told me to take it back to repairers, they say fault in communications failure, no idea after that.
    Any ideas anyone?
    Chris
  2. Re: 2012 A6 3.0 start button failure
    Mar 2014
    Edinburgh
    235 Post(s)
    Sounds like it could be dodgy battery. There’s a huge drain on start up as all electronics have to fire up then the starter.
    I doubt the new door would cause so much disruption in so much electronics as that would most likely just be wired to the convenience module.
  3. Re: 2012 A6 3.0 start button failure
    Aug 2009
    Near Lanark
    21 Post(s)
    Might be worth getting a scan on VCDS too. Would help eliminate any other issues
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  1. Question Late 2012 A4 3.0 TDI 204Bhp Water Pump Gasket Failure - Replacement
    By Hybridjack90 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-11-2016, 10:35 PM
  2. Button start cars
    By krupatel in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-10-2014, 10:08 PM
  3. RS4 Start button
    By Borab0y in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-11-2009, 06:09 PM
  4. retro fit start button??
    By squidgey in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-03-2009, 09:08 PM
  5. Cabrio Hood Button Failure
    By andrewaudi in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-09-2007, 10:15 AM
