Thread: A6 Avant rear brake light.
Results 1 to 9 of 9
  1. A6 Avant rear brake light.
    Sep 2016
    Wexford, Ireland
    I have a question...
    Our car is a 2009 facelift Avant. It has the Xenon headlamps and LED's on the tail lights.
    The missus reported that the warning sign came on for left brake light so I thought I'd take a look. Meanwhile she went to the motor factors only to be almost laughed at for thinking she had LED'S. She was fobbed off with the old standard tail/brake combo bulb, which I already have plenty of.
    Anyway, I did finally get to look at it and what I've lost is the tail and brake lights on the tailgate (on the left side) All the lights in the adjacent rear wing are fine.
    On removal of the cover I found 2 bulbs, one reversing light and the other the fog light. Both of these still work.
    The lights that have failed don't appear to be accessible. So what do I do? Everything looks clean and dry inside. Could it be a fuse? If so, where do I look?
    Thanks in advance... Paul
    2009 2.0tdi e s-line Avant
  2. Re: A6 Avant rear brake light.
    Jul 2013
    40 Post(s)
    Try looking at the wiring in the rubber conduit on the RH rear side of the boot lid as a wire may have snapped.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: A6 Avant rear brake light.
    Sep 2016
    Wexford, Ireland
    Thanks Dan. I'll have to check that out next time it's not dark, or raining, or in use, and I have time. It's like all the planets being in alignment :-))
  4. Re: A6 Avant rear brake light.
    Jul 2011
    Near Uxbridge
    Quote Originally Posted by PCB View Post
    Same thing happened to mine....I ended up buying a new off eBay.... it was around 100 quid....and piece of cake to fit.
    Sent from my SM-G955F using Tapatalk
    2009 Audi A6 Avant 2.0 S-Line TDIe Phantom Black
    2009 Audi A3 Sportback 1.9 TDIe Sport Brilliant Red
  5. Re: A6 Avant rear brake light.
    Sep 2016
    Wexford, Ireland
    What did you buy off ebay? A new light?
  6. Re: A6 Avant rear brake light.
    Jul 2011
    Near Uxbridge
    Yes....was a complete new unit...came with the two bulbs you mentioned... connected it up and worked perfectly.
  7. Re: A6 Avant rear brake light.
    Sep 2016
    Wexford, Ireland
    Quote Originally Posted by neilos100 View Post
    That's interesting. I wonder how that would suddenly need replacement.
    Right, well I'll look into that. And the possible wiring issue.
    Many thanks
  8. Re: A6 Avant rear brake light.
    Jul 2011
    Near Uxbridge
    Many thanks
    I was told the LEDs had given up the ghost....and without splitting open the light were impossible to fix
  9. Re: A6 Avant rear brake light.
    Jul 2011
    Near Uxbridge
    It came from an eBay store called mr-auto-uk.....was 111 and is made by Valeo....so OEM
    Neil
  1. How To Replace light bulbs on third brake light (Avant)
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-11-2015, 01:53 PM
  2. Please Help High Level Rear Brake Light on Avant
    By John140 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2012, 11:52 AM
  3. Rear central brake light bulb Fault on A6 Avant 2007
    By OliB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-02-2011, 08:34 PM
  4. Question Avant, Rear brake light warning on dash, bulb is OK though!
    By ally0000 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-07-2010, 02:49 PM
  5. Audi Avant A6 Rear Brake Light problem
    By dthom70623@tesc in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-06-2009, 10:31 PM
