Thread: Leaking soft top/Adjustment needed
Threaded View
  1. Leaking soft top/Adjustment needed
    Hi all. After a time away from owning a VAG car, I've now bought a 2002 Audi TT 8n Roadster. Overall, it is really good, but I have found a leak from the convertible roof. The roof doesn't line up at the rear left hand side when the roof is up, therefore it doesn't seal against the rubber strip. The right hand side seems perfectly fine and seals well. The front also lines up correctly where the roof meets the windscreen. The 'skirt' is starting to go, but before I tackle that I wanted to fix the seal issue. All the seals are in good order, its just the roof appears to not be being pulled up enough on the left hand side. Anyone got any idea how to adjust the roof?
  1. Please Help Leaking hatchback seal, help/ advice needed
    By simonrad in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-02-2016, 07:27 AM
  2. login code and soft coding needed for b5 passat
    By leejns34 in forum VCDS - Help Requests
    Last Post: 28-12-2014, 09:59 PM
  3. leaking matrix leaking.
    By gold7 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-03-2009, 08:56 AM
  4. My New Mk1 Gli Soft Top
    By simonmitra in forum Golf MK1 - 1974 -1984
    Last Post: 11-01-2009, 10:31 PM
  5. Question Leaking soft top
    By Marty Newman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-12-2008, 01:04 AM
