Thread: Help! Vw Passat with fault codes!
  1. Help! Vw Passat with fault codes!
    Aug 2008
    Evening, My 09 past was running ok, then i accelerated to overtake and the glow plug light flashed, car was ok.
    I read the codes and got--
    P0122 Throttle Position Sensor/Switch A Circuit Low Input
    P2454 Diesel Particulate Filter Pressure Sensor A Circuit Low
    P0607 VOLKSWAGEN - Control Module Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    HELP!!
    Could all of these be caused by the Fuel temp sensor being faulty?
    Cars only done 68K, previous owner never drove the car hard,
  2. Re: Help! Vw Passat with fault codes!
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Did all 4 codes come up on VCDS with the same date/ time/ mileage ?
    If not I would clear them & see what returns.
    Then try a similar manouver on a quiet road to see if the problem can be replicated.
  3. Re: Help! Vw Passat with fault codes!
    Aug 2008
    All codes at the same time, i cleared them, but they came straight back on when i read them again
  4. Re: Help! Vw Passat with fault codes!
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The P0607 VOLKSWAGEN - Control Module Performance refers to the ECU itself I think.
    The other faults refer to low voltages.
    I would start by checking your battery is ok, should be at least 12.5v & around 14v with the engine running.
    Check all battery & earth connexions are clean & tight.
    Then move to the ECU, check the multiplug connexion for any moisture or corrosion on the pins.
    Have a look inside the ECU case & check for any moisture/ corrosion in there.
  5. Re: Help! Vw Passat with fault codes!
    Jan 2018
    Sussex
    55 Post(s)
    Flashing glow plug light suggests DPF issue.
  6. Re: Help! Vw Passat with fault codes!
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by granttd73 View Post
    There lies the problem.
    Ian
    A4 B6 Avant Nogaro Blue
  1. passat 1.8t fault codes p1654 p0411
    By swebbym3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2010, 03:33 PM
  2. Passat fault codes
    By bigiveaudi in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-08-2009, 11:10 PM
  3. fault codes for a passat 1.9 tdi 2000
    By justinsully1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2008, 12:24 PM
  4. passat fault codes
    By bazlif in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-02-2008, 08:08 PM
  5. Passat fault codes
    By Matelotman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-01-2008, 10:44 AM
