Thread: Let’s talk tyres...
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. Re: Let’s talk tyres...
    #21
    May 2012
    Everywhere
    308 Post(s)
    Which Continentals ?
  2. Re: Let’s talk tyres...
    #22
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    Quote Originally Posted by Gazwould View Post
    They were contipremiumcontact 2 on the note
  3. Re: Let’s talk tyres...
    #23
    May 2012
    Everywhere
    308 Post(s)
  4. Re: Let’s talk tyres...
    #24
    Mar 2014
    Edinburgh
    235 Post(s)
    I’ve had the same on the sport contact and premium contact.
    Just replaced my wife’s sport contact 5 and it had about 3mm+ in the middle and shiny bald on the edges. The car has full tpms and shows pressures in the car and app and I check it regularly. Always within manufacturers spec. These were the tyres it came with from factory.
    Again mainly motorway miles.
  5. Re: Let’s talk tyres...
    #25
    Nov 2017
    UK - NORTHEAST
    9 Post(s)
    Quote Originally Posted by A6S View Post
    Mine was exactly the same, this happened on my note and qashqai, the problem was especially with the note they were a dodgy size tyre 185/55/16 and not many companies did them initially.
  6. Re: Let’s talk tyres...
    #26
    Mar 2014
    Cologne, Germany
    55 Post(s)
    I find these report about uneven tyrewear really strange. Had absolutely no problem on the A6 and now the S6.
    2017 Audi S6 Avant
    2016 Volvo XC60 T5 R-Design (wife's)
    1987 Volvo 780 Bertone (my classic!)
  7. Re: Let’s talk tyres...
    #27
    Mar 2014
    Edinburgh
    235 Post(s)
    Quote Originally Posted by NewAudi View Post
    Driving styles and climate would probably be a big factor. Could be the varying temperatures that’s causing issues. Might try and find a place for a nitrogen fill, a proper place that suck all the air out then fill with nitrogen. Might make a difference.
  8. Re: Let’s talk tyres...
    #28
    Aug 2009
    Near Lanark
    21 Post(s)
    A few years back I had an A4 B7 2.0 Quattro.
    Ran with 19s on it and had to put all 4 tyres around 4-5psi higher than specified otherwise I was getting wear in the middle.
    I wonder if certain brands are stiffer across the tread and the pressure difference affects them less?
    Can't remember which tyres it was, but I ran Avons and Kumhos on that car.
    I just know I had to run mine harder than spec to get even wear.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  9. Re: Let’s talk tyres...
    #29
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Darich, if you over inflate your tyres you would expect the centres to wear out so your experience is unusual.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  10. Re: Let’s talk tyres...
    #30
    Aug 2009
    Near Lanark
    21 Post(s)
    Quote Originally Posted by shabazmo View Post
    Unsual, yes, but at least a couple of others here reporting worn edges with "correct" pressures so that would indicate those tyres are too soft too. So it not a unique problem.
    If I remember right I was running around 38-40psi and wear was even across all 4 tyres.
  1. SQ7 - talk me out of it
    By A7_UFO in forum Q7 - 4M Forum - 2016 -
    Last Post: 05-07-2016, 08:44 PM
  2. Question IO Talk 2 Bluetooth Kit
    By Pocko100 in forum In Car Entertainment
    Last Post: 24-09-2014, 05:09 PM
  3. Talk to me about brakes!
    By Rosscow in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2014, 04:45 PM
  4. Bury 8 take and talk
    By Red-penquin in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-05-2011, 07:23 AM
  5. Question Turbo Talk
    By Pup in forum Golf MK4 - 1999 - 2004
    Last Post: 14-01-2009, 08:06 PM
