Thread: High level rear brake light shorting saloon
  1. High level rear brake light shorting saloon
    Mar 2014
    Nottingham. UK
    My car (2011 A6 Saloon) has developed a fault with the centre rear brake light, it shorts out immediately as soon as the brake pedal is pressed.
    I've fitted a new light unit but this hasn't cured the issue.
    I've cleaned the 2 pin connector to no avail.
    Any ideas on where to look/what it could be?
  2. Re: High level rear brake light shorting saloon
    Jul 2013
    76 Post(s)
    With it disconnected do the rear brake lights work?
    if not then disconnect one side and test
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: High level rear brake light shorting saloon
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by dan2485 View Post
    Both left and right brake lamps work fine even when the centre light is disconnected. Its purely just the centre brake light that seems to always short out.
  4. Re: High level rear brake light shorting saloon
    Mar 2014
    Nottingham. UK
    How do i test if its the actual led light unit that's possibly at fault?
    How can i test the unit once removed from the car?
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  5. Re: High level rear brake light shorting saloon
    Feb 2013
    Gloucester
    57 Post(s)
    Touch the wires onto a 9v battery
    Sent from my iPhone using Tapatalk Pro
  6. Re: High level rear brake light shorting saloon
    Jul 2008
    Lisburn
    15 Post(s)
    I can't picture the fault you say short so does it blow fuses burn wires?
  7. Re: High level rear brake light shorting saloon
    Mar 2014
    Nottingham. UK
    Solved! Turned out to be a faulty new brake light unit.
    But now I've developed another problem! The airbag light has come on and will not turn off.
  1. High-level brake light
    By porty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-10-2015, 11:59 AM
  2. Please Help High Level Rear Brake Light on Avant
    By John140 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2012, 11:52 AM
  3. High Level Rear Brake Light
    By markywillsparky in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-04-2011, 10:01 PM
  4. Replies: 1
    Last Post: 09-09-2010, 04:36 PM
  5. High Level Brake Light
    By cunningm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2008, 03:41 PM
